9peppe
March 24, 2020, 11:09am
44
fooby
March 24, 2020, 11:18am
45
hahah,
it doesnt want to give me a SSL cert does it!. Anything i can do to fettle the code to add a wait condition or something
9peppe
March 24, 2020, 11:22am
46
from time import sleep
sleep(seconds)
fooby
March 24, 2020, 11:43am
47
and i should insert that (for say 2 seconds) in at line 134? Or something like this?
find the http-01 challenge and write the challenge file
challenge = [c for c in authorization['challenges'] if c['type'] == "http-01"][0]
token = re.sub(r"[^A-Za-z0-9_\-]", "_", challenge['token'])
keyauthorization = "{0}.{1}".format(token, thumbprint)
wellknown_path = os.path.join(acme_dir, token)
sleep(2)
with open(wellknown_path, "w") as wellknown_file:
wellknown_file.write(keyauthorization)
9peppe
March 24, 2020, 11:46am
48
that’s too early.
between 138 and 139, I’d say, after the comment and before the try block (or inside the try block)
fooby
March 24, 2020, 11:49am
49
ah right ok, makese sense now. Sorry only really a config fettler not much of a coder.
check that the file is in place
sleep(2)
try:
wellknown_url = "http://{0}/.well-known/acme-challenge/{1}".format(domain, token)
ctx = ssl.create_default_context()
ctx.check_hostname = False
ctx.verify_mode = ssl.CERT_NONE
assert(disable_check or _do_request(wellknown_url, context=ctx)[0] == keyauthorization)
except (AssertionError, ValueError) as e:
raise ValueError("Wrote file to {0}, but couldn't download {1}: {2}".format(wellknown_path, wellknown_url, e))
So did that, rebooted box.
File “/usr/share/webmin/webmin/acme_tiny.py”, line 203, in
main(sys.argv[1:])
File “/usr/share/webmin/webmin/acme_tiny.py”, line 199, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/share/webmin/webmin/acme_tiny.py”, line 148, in get_crt
raise ValueError(“Wrote file to {0}, but couldn’t download {1}: {2}”.format(wellknown_path, wellknown_url, e))
ValueError: Wrote file to /home/sentinelfs/public_html/.well-known/acme-challenge/T5d2cmSY9zzCjdk36iPcLUA85btXXSrgyFWihbMSUiA, but couldn’t download http://sentinelfs.co/.well-known/acme-challenge/T5d2cmSY9zzCjdk36iPcLUA85btXXSrgyFWihbMSUiA: Error:
Url: http://sentinelfs.co/.well-known/acme-challenge/T5d2cmSY9zzCjdk36iPcLUA85btXXSrgyFWihbMSUiA
Data: None
Response Code: 404
Response:
404 Not Found
404 Not Found
nginx
9peppe
March 24, 2020, 11:58am
50
and I get the file, it does not.
I guess two seconds is not enough.
fooby
March 24, 2020, 12:00pm
51
weird, really cant believe this sort of fettling is needed. Ill up it to 5 seconds and see what happens.
fooby
March 24, 2020, 12:17pm
52
main(sys.argv[1:])
Data: None
Response Code: 404
Response:
404 Not Found
404 Not Found
nginx
still failed. It must be something else?
9peppe
March 24, 2020, 12:20pm
53
I don’t even.
You can try putting disable_check=True before the try block.
fooby
March 24, 2020, 12:46pm
54
Requesting a certificate for sentinelfs.co , www.sentinelfs.co from Let’s Encrypt …
… request was successful!
Configuring webserver to use new certificate and key …
… done
Applying web server configuration …
… done
yay
Thank you very much for your help, what a mess on. Would kinda love to understand why we need to disable the check. But i guess thats for people smarter than me.
9peppe
March 24, 2020, 12:49pm
55
All this will be lost when virtualmin upgrades. You should check if you can switch clients.
(it can be a lot of things with your software, network, or both)
fooby
56
True, but there has been no upgrades i’m aware of from when it worked before and now. I’ll keep an eye on this and any upgrades i might need to do to virtualmin.
