My domain is:docker.vaultara.com
I ran this command:docker run --rm --name certbot -v "/home/ubuntu/docker_cache/certs:/etc/letsencrypt" -v "/home/ubuntu/docker_cache/letsencrypt:/var/lib/letsencrypt" -p 80:80 certbot/certbot certonly -d docker.vaultara.com
It produced this output:successfully received certificate
My web server is (include version):docker registry v2
The operating system my web server runs on is (include version):Ubuntu 18.04.6
My hosting provider, if applicable, is:AWS
I'm using a control panel to manage my site:no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):(latest container downloaded at run time)
As you can see, I'm using the certbot container in order to obtain a certificate which I'm then using within docker's registry container (so that I can host my own "hub.docker.com"). Everything works perfectly (or so it seems) and I get a certificate, the chain and full chain files.
However, when I attempt to use the certificate I get errors on the client, so after some searching, I decide to verify what's been generated and I see an issue which I'm totally unsure how to overcome.
When I run openssl verify -CAfile chain1.pem cert1.pem I get the following
C = US, O = Internet Security Research Group, CN = ISRG Root X1
error 2 at 2 depth lookup: unable to get issuer certificate
error cert1.pem: verification failed
Inspecting my certificate itself using openssl x509 -noout -text -in cert1.pem shows
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
03:eb:6a:04:83:61:8d:32:b6:df:d7:ee:cb:a2:1a:93:b8:b0
Signature Algorithm: sha256WithRSAEncryption
Issuer: C = US, O = Let's Encrypt, CN = R3
Validity
Not Before: Jul 11 14:50:53 2022 GMT
Not After : Oct 9 14:50:52 2022 GMT
Subject: CN = docker.vaultara.com
Subject Public Key Info:
Public Key Algorithm: id-ecPublicKey
Public-Key: (384 bit)
pub:
04:b0:0e:c2:ee:98:6e:73:2a:a0:fd:24:f2:72:3d:
a9:5c:a8:f3:8c:c0:41:61:af:cb:a0:87:4b:26:5e:
f3:1a:72:d3:8b:17:be:7c:ce:ee:6d:bf:98:ed:20:
f6:3e:e2:e5:36:02:d8:0d:3e:79:ec:b2:3f:80:45:
a6:ba:1e:2b:85:8c:53:e9:17:47:9c:42:0c:d7:32:
a2:7d:f5:a4:14:61:48:c8:9d:c0:51:da:2c:95:ca:
78:47:f6:d4:dd:bf:2a
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature
X509v3 Extended Key Usage:
TLS Web Server Authentication, TLS Web Client Authentication
X509v3 Basic Constraints: critical
CA:FALSE
X509v3 Subject Key Identifier:
35:F9:9A:EA:7E:FD:CA:91:9E:E5:BF:BD:83:CD:F8:FF:8A:79:C6:F5
X509v3 Authority Key Identifier:
keyid:14:2E:B3:17:B7:58:56:CB:AE:50:09:40:E6:1F:AF:9D:8B:14:C2:C6
Authority Information Access:
OCSP - URI:http://r3.o.lencr.org
CA Issuers - URI:http://r3.i.lencr.org/
X509v3 Subject Alternative Name:
DNS:docker.vaultara.com
X509v3 Certificate Policies:
Policy: 2.23.140.1.2.1
Policy: 1.3.6.1.4.1.44947.1.1.1
CPS: http://cps.letsencrypt.org
CT Precertificate SCTs:
Signed Certificate Timestamp:
Version : v1 (0x0)
Log ID : 46:A5:55:EB:75:FA:91:20:30:B5:A2:89:69:F4:F3:7D:
11:2C:41:74:BE:FD:49:B8:85:AB:F2:FC:70:FE:6D:47
Timestamp : Jul 11 15:50:53.278 2022 GMT
Extensions: none
Signature : ecdsa-with-SHA256
30:45:02:21:00:AF:3B:01:CF:72:B3:A5:1B:D7:D6:31:
9C:00:70:2B:C5:DB:7C:E7:A6:76:A4:8A:5F:E5:42:E5:
A3:6E:9D:6D:09:02:20:2A:6F:36:51:8D:57:74:E6:FC:
47:C0:A4:3C:CC:81:EC:CA:C4:35:D9:54:F4:64:B3:79:
8C:9A:88:CD:75:2F:21
Version : v1 (0x0)
Log ID : DF:A5:5E:AB:68:82:4F:1F:6C:AD:EE:B8:5F:4E:3E:5A:
EA:CD:A2:12:A4:6A:5E:8E:3B:12:C0:20:44:5C:2A:73
Timestamp : Jul 11 15:50:53.740 2022 GMT
Extensions: none
30:45:02:21:00:B1:81:AD:E7:D1:D4:75:F8:6F:16:60:
C7:A8:32:28:3E:E9:8B:AC:5D:83:CB:33:65:C7:18:73:
EE:2C:69:15:07:02:20:03:07:C3:8D:BE:08:18:BE:0C:
D2:1F:FE:84:E7:3A:69:6E:9D:A7:8E:83:E7:75:FB:8B:
04:E8:76:B3:05:66:EC
27:20:d9:cb:a7:dd:ec:00:43:f7:6c:23:13:0b:48:2d:a0:c2:
70:a7:36:9f:68:e2:b7:5f:ed:49:97:07:4e:de:eb:9c:87:74:
44:7d:e7:c7:e2:1e:4d:8b:23:e6:47:29:97:0d:ba:b3:bc:12:
01:82:12:5d:a6:bd:cd:44:6c:56:43:a1:78:7f:58:f5:c1:43:
19:6b:76:62:9a:22:6a:8d:47:71:00:c7:2f:81:35:0c:9e:8a:
dd:ab:9b:84:ae:78:9d:3f:3d:a4:60:7f:35:90:d0:46:b0:44:
16:ba:5c:0a:8f:88:fc:09:12:9c:f7:2a:25:54:14:bd:de:94:
21:b2:d9:69:fe:67:33:44:e1:cb:71:86:69:39:c6:df:6c:cf:
4e:d1:f2:ef:9a:92:2a:b5:93:f1:d9:cc:06:7a:16:fe:a6:fd:
84:41:c3:36:e1:cc:5f:ae:62:bd:19:39:97:a5:88:c3:8d:88:
a2:49:87:48:78:e5:30:e9:aa:ee:ee:f5:fc:fa:12:12:03:3a:
6f:9c:30:2f:59:bc:93:f1:f9:01:c1:75:39:bb:af:bd:f5:bb:
01:f3:a1:47:83:c1:80:74:79:23:4d:02:0a:fe:f5:a8:85:9c:
ed:8d:5c:a7:56:fb:10:cb:f2:88:d4:34:a0:04:25:be:54:35:
32:56:ab:79
Some searches state that the files may have been incorrectly put together, especially the fullchain file, but looking through them, I think this is a red herring: they all appear to be constructed correctly.
I'm really not doing much and I find it hard to believe that the certbot container I'm using is really at fault, but that's all I can think of...?
