Varnish, Pound, RoundCube and Lets Encrypt
Hello, Ive been using lets encrypt for a few months now for a few clients domains and they all work fine. However I’m trying to migrate my mail servers and have created some new scripts that allow for web-mail.domain.com to be entered against the certificate, the script challenges and is verified aqgainst all validated Lookups for the domains and subdomains. As far as I can tell this works properly - however when visiting the domain it doesn’t appear to work for the webmail subdomain.
I’m using Varnish, Pound and Roundcube, Pound terminates the SSL for the requests (Varnish may be an unnecessary extra, however will remain for the time being) then forwards them to varnish which gets them from the back end (Round Cube). There are a number of certificates listed in pound. I’m terminating the webmail certificate here because we use servers running plesk and it doesn’t support webmail certificates (currently natively) and the method recommended in the forums seems tedious to me, as the challenge is intercepted by the webmail configuration - on that note looked at plesk source and couldn’t see how to modify the script calls for nginx or letsencrypt so moved it out to our proxies.
**SSL for domain.com and www.domain.com - works.
**SSL for webmail.domain.com - defaults to the first cert in the list of certificates.
Firstly, I’m quite sure webmail.domain.com is included in the certificate but would like to confirm this? is that possible without having it configured? Ive checked SSL checker and it doesn’t validate the webmail subdomain. It simply falls back to the first domain certificate (ourcompany.com)
Am I correct in thinking the subdomain should be part of the same certificate.
Certbot Script Information
http-01 challenge for www.domain.com
http-01 challenge for domain.com
http-01 challenge for webmail.domain.com
Waiting for verification…
Generating key (4096 bits): /etc/letsencrypt/keys/0011_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0011_csr-certbot.pem
 - Congratulations! Your certificate and chain have been saved at
   /etc/letsencrypt/live/www.domain.com-0001/fullchain.pem. Your cert
   will expire on 2017-06-15. To obtain a new or tweaked version of
   this certificate in the future, simply run certbot-auto again. To
   non-interactively renew *all* of your certificates, run
   "certbot-auto renew"
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
Pound Config
 ListenHTTPS
        HeadRemove "X-Forwarded-Proto"
        AddHeader "X-Forwarded-Proto: https"
        Address 0.0.0.0
        Port    443
        xHTTP           0
        Cert "/etc/pound/certs/companydomain.com.pem"
        Cert "/etc/pound/certs/domain1.com.pem"
        Cert "/etc/pound/certs/domain2.com.pem"
        Cert "/etc/pound/certs/domain3.com.pem" # Includes webmail
        Service
                BackEnd
                        Address 127.0.0.1
                        Port    80
                End
        End
End
Any help, tips would be appreciated
Thank you,
Still not sure why, but checked the lets encrypt logs and all domains/sub domains where validating correctly, however the generated certificate in pound which would work for the parent domain and www. variation would not work for webmail, however I created a webmail.domain.com certificate by itself (almost identical method, just two less domains in the lets encrypt call) and this once added to pound validates correctly.
Is only a little more work to validate the domains, but wondering should this be expected or should I be able to compound the domains and sub domains into a single file.
hi @nate1
A) what is the client you are using and what are the commands
B) can you draw a network diagram of how the components interact
C) Can you paste screenshots of whats actually not working
This should all help in suggesting areas for attention
Andrei
A) what is the client you are using and what are the commands - Certbot?
Command is in a bash script called with parameters
sudo /etc/letsencrypt/certbot-auto certonly --standalone --agree-tos --domains ${domains} --email ${email_address} --preferred-challenges http-01 --http-01-port 8000 --renew-by-default --rsa-key-size 4096
Domains = www.domain.com,domain.com,webmail.com
I’ve checked the logs and all challenges are working.
https -> pound (SSL Termination) [This is where the issue is] -> Varnish -> Web Server Backend
Pound simply listens on 443, assigns a certificate and then does what its told this works in most circumstances, would be nice and tidy if I only needed one certificate per domain name.
The SSL Certificate isn’t including webmail.domain.com against the SSL certificate that was requested. Ive done this for just webmail.domain.com as its own certificate and works fine, however included with the other www.domain.com & domain.com it won’t work but they both do.
The issue may be with Webroot http://letsencrypt.readthedocs.io/en/latest/using.html#webroot
But the files aren’t hosted on the server…
