i’ve used this command with certbot :
certbot --agree-tos --email buo@outlook.com certonly --webroot -w /code/ree/Cert/ -d ree.com -d www.ree.com
so i have 3 folders : accounts csr keys
with various file and 2 pem file in scr …
0000_csr-certbot.pem 0001_csr-certbot.pem
How to make a fullchain.pem from csr ?
thanks and regards
Hi @bussiere,
You can’t create the fullchain using csr (that is the certificate request not the issued cert) . What you are looking for is in /etc/letsencrypt/live/ree.com/
That directory is probably not there yet, perhaps due to issues during the issuing process.
@Osiris, I think you are right, i've checked the issued certs for ree.com and there is none:
2017/May/21 19:59:34 - Checking certs for ree.com
Info: I've not found any certificate for the domain ree.com
@bussiere, I suppossed that you received the Congratulations message when you executed the certbot command but seems you didn't. What was the error you received executing the certbot command?
Cheers,
sahsanu
