Valid TLS Certificates for Ergo IRC
My domain is: blube.club
I ran this command: n/a
It produced this output: n/a
My web server is (include version): nginx/1.14.2
The operating system my web server runs on is (include version): debian 10 buster
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.17.0
Okay so here's my issue. I am trying to get valid tls certificates for my irc server which is ergo, running on port 6697. It says in the ergo docs to follow the instructions on the certbot website, but I only see instructions for my web server, not my irc server.
How do I get certs for IRC?
Thank you!
Hi @satch, and welcome to the LE community forum :slight_smile:
Simple: You don't.
You first get a cert.
Then you can use that cert with any software that uses certs.
How?
Well, that depends on the software using the cert.
In this case, IRC.
You will need to review the IRC software documentation on how to secure it with a cert.
[Getting a cert with certbot and nginx should be quite easy.]
Probably the easiest way to get a certificate for your server would be to setup nginx and use that to solve the challenges. Then just point your IRC server application at the certificate.
Why using nginx for that? That's overkill! Just use the buildin certbot standalone plugin which can do the same job..
