My domain is: tymanthius.net
I ran this command: - certbot renew
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,)
Attempting to renew cert (graf.tymanthius.net) from /etc/letsencrypt/renewal/graf.tymanthius.net.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,). Skipping.
nginx 1.1.03
Debian 9 running in a container on proxmox 6.
Register4Less
Yes
No
or certbot-auto --version
if you’re using Certbot):
0.28.0
So I set up certs for several sites that are all .tymanthius.net. I used manual. Wildcard doesn’t work as I apparently have to use DNS text to authenticate.
What I’m asking is if anyone knows of an automated way to set up with Register4Less?
Thank you!
