An authentication script must be provided with --manual-auth-hook
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=relationmonitor.dk), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
I used this command, when generated certificates for 2 server for same domain name
certbot certonly --server https://acme-v02.api.letsencrypt.org/directory --manual --preferred-challenges dns -d 'relationmonitor.dk,*.relationmonitor.dk'
My domain is: relationmonitor.dk
I ran this command: sudo certbot renew --manual
Processing /etc/letsencrypt/renewal/relationmonitor.dk.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,)
Attempting to renew cert (relationmonitor.dk) from /etc/letsencrypt/renewal/relationmonitor.dk.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,). Skipping.
My web server is (include version): nginx version: nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: CloudVPS
Hi @danyal14
renew is a non-interactive command. So you can't use --manual.
So use
But you want a wildcard certificate, so you must use dns and the v02 -> so this command
certbot certonly --manual -d 'relationmonitor.dk,*.relationmonitor.dk'
should do the same.
Hi @JuergenAuer,
Thanks for the reply, I tried and got following output. Looks like it didn’t renew.
sudo certbot certonly --manual -d ‘relationmonitor.dk,*.relationmonitor.dk’
The currently selected ACME CA endpoint does not support issuing wildcard certificates.
You should update your certbot, if it uses v01 as standard. Or add the --server argument. But better - update your certbot.
Thanks, it works with --server argument, I will update the certbot too thnaks:)
@JuergenAuer
Certbot ask twice to add different kys with same DNS TXT record and when i added it.
Authentication fails because it finds only first key in order.
Do you know, if i can add both record with same TXT entry _acme-challenge.relationmonitor.dk?
If you have two domain names
you have to add two entries with the same name
and different values. Letsencrypt checks all values.
This
D:\temp>nslookup -type=txt _acme-challenge.relationmonitor.dk.
_acme-challenge.relationmonitor.dk      text =
        "j-Se0xBqqRtNrkXcmqWx99H0vLUf72-esM-WVTEtSqs"
        "vrpWj5DzWHLVL1HgVjEN4UNue4J1qMevRgjhIwewokc"
looks good.
