Failed to renew certificate domain.fr-0001 with error: The manual plugin is not working; there may be problems with your existing configuration
docker-compose run –rm certbot renew
docker-compose restart nginx
Failed to renew certificate domain.fr-0001 with error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError('An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.')
Hi @You125, and welcome to the LE community forum :slight_smile:
When I see "-0001" it is usually an indication of something having NOT gone as planned.
Please provide more detail on the problem.
Like, by answering the questions presented when you opened the topic:
here's a screen shot :
It looks like you have two active certificates for the same domain name.
One of these certs uses the --webroot method and that has failed because you do not have the required A and/or AAAA records in the DNS
The other cert uses the --manual method. The manual method is not supported by the automated renew command unless you also provide the pre-authorization auth-hook and (probably) a cleanup hook so it can be automated. Without these hooks the --manual method needs, well, manual intervention which of course can't be automated.
It will be difficult to help you without the specific domain name and all the output. Showing us the output of this command is good place to start:
docker-compose run -rm certbot certificates
Hi thank you so much for your help, this screen which I get when I run the :slight_smile:
I hided just the domain name, is it important to give the domain names ?
It is difficult to help without knowing the domain name. Especially when one of the problems related to the DNS. Also, you have multiple cert configs on your system so it will be easier to discuss if we have a consistent way to talk about them. Often, when people hide names they make changes that also hide the real problem.
