Hello Everyone in Let's Encrypt Community Support.
This is my first time trying to get the Certificate from Let's Encrypt.
I am using my personal computer via Powershell to use Certbot.
My domain is running on this company "HiNet虛擬主機 - hiHosting 企業網路架站" and the system is "Windows Server 2019 IIS 10"
My domain is: https://www.legia.com.tw/
I ran this command: certbot certonly --manual -m legia.sylvio@gmail.com -d legia.com.tw
Saving debug log to C:\Certbot\log\letsencrypt.log
Requesting a certificate for legia.com.tw
Create a file containing just this data:
d5_AJktkqntRnQ1LhEjl3ZCkeHLJgP2UtWN99lRsp6Q.fEdMcTf8hAdbxlTEcQ9ENSBl6OQEEVNgB95bD5GWCQU
http://legia.com.tw/.well-known/acme-challenge/d5_AJktkqntRnQ1LhEjl3ZCkeHLJgP2UtWN99lRsp6Q
Press Enter to Continue
Domain: legia.com.tw
Detail: Invalid response from http://legia.com.tw/.well-known/acme-challenge/d5_AJktkqntRnQ1LhEjl3ZCkeHLJgP2UtWN99lRsp6Q [203.69.42.31]: "\r\n<html xmlns="http"
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
My web server is (include version): Windows Server 2019 IIS 10
The operating system my web server runs on is (include version):Windows 10
My hosting provider, if applicable, is: HiNet虛擬主機 - hiHosting 企業網路架站
I can login to a root shell on my machine (yes or no, or I don't know): My hosting provider give me the "IP address", "ID account" and "ID password". So, I don't know that I can login to a root shell or not.
or certbot-auto --version
if you're using Certbot): certbot 1.22.0
Attached file is the screenshot for the address that I put the challenges.
By the way, when I using Chrome to check the "Sources". Did I put the file address correct or not. However, I can't see the file. Thus I use the web.config to rewrite the address.
Thank you Everyone. If I missed any part of the instructions or any info I can provide, please let me know. Hope I can get the certificate successfully.
I put the screenshot and the Cerbot log file in this page: https://www.legia.com.tw/LetsEncrypt.html
Sincerely,
Sylvio.Chung
