I see it uses Certbot; the current Certbot 1.32.0 Release.
Yet the NameSilo app is 3 years old; does it supporting ACME v2?
That message is confusing, in that I can't tell if the file name is: ./authenticator.py
OR ./authenticator.py-hook
The call seems to be to the .py named file.
The message states it does find the file, but the file can't be executed.
If that is indeed the actual problem, you may need to ask about such required file permission(s) in a python forum.
Hi @Bruce5051, thank you for your welcome and for your reply.
As far as I know, the scripts seem to work. As recently as of April this year, a now closed issue on GitHub indicates someone managed to use it with GitLab CI/CD successfully.
I have shared the commands used and the output errors and warnings. My provider is NameSilo, and the script uses API keys to issue the certificate.
Since this issue is about a particular function of the script itself, I do want to preserve the privacy of the domain I want to use it for.
Unfortunately, this may not be the best place to get support for that script.
If they provide older versions of the script, you might get better results there.
I agree that it is confusing. The file name is authenticator.py and it resides in the root folder of the repository where I'm running this pipeline from.
There are some posts in the community talking about the problem (here and here for instance), but I can't make head or tails of it!
I wonder if there is something I should add to my .gitlab-ci.yml to make those files executable.
That is a very likely fix: Adding read/write/execute permissions to that location.
But the "how to" on that is best researched elsewhere - we're not fluent in yml here - LOL
I agree with Rudy, YAML is just a terrible data-serialization language Especially when it's combined with Docker!
But all fun aside, I agree with Rudy (again): you probably need to make the scripts executable.
That other warning with venv/bin/python is very weird, because neither Certbot nor that script you're refering to uses chmod.. So NO clue where it comes from. Especially because you're only showing the error itself without any context around it.
Rudy: I'm pretty sure the script is old enough Hasn't been updated for 3 years.
I will have a look again and let you know if I made any progress...
This is the context the chmod warning appears (it gets too confusing for me!):
Preparing the "docker+machine" executor
Using Docker executor with image python:latest ...
Pulling docker image python:latest ...
Using docker image sha256:00cd1fb8bdcc67527e569dcdf5e4ad9d704b117eb961602804826281d641cac3 for python:latest with digest python@sha256:b941b836b18734f4992a168b579b7c16ff4c3b544782953eeab3a590a7338765 ...
Preparing environment
Running on runner-j2nyww-s-project-40996614-concurrent-0 via runner-j2nyww-s-shared-1668505538-657dbc2b...
Getting source from Git repository
$ eval "$CI_PRE_CLONE_SCRIPT"
Fetching changes with git depth set to 20...
Initialized empty Git repository in /builds/ccssl/ssl/.git/
Created fresh repository.
Checking out a0fbb94d as main...
Skipping Git submodules setup
Restoring cache
Checking cache for default-1-protected...
Downloading cache.zip from https://storage.googleapis.com/gitlab-com-runners-cache/project/40996614/default-1-protected
WARNING: venv/bin/python: chmod venv/bin/python: no such file or directory (suppressing repeats)
Successfully extracted cache
Now I have an issue with the certificate itself not being issued because the script doesn't appear to add any DNS record at all! It just hangs for about 40 minutes and fails with this message:
Domain: xyz.com
Detail: Incorrect TXT record "eXVxqQJo7U-d6jxn1ua0t_KmB2tGDpmx1oXtFwqX1lM" found at _acme-challenge.xyz.com
Hint: The Certificate Authority failed to verify the DNS TXT records created by the --manual-auth-hook. Ensure that this hook is functioning correctly and that it waits a sufficient duration of time for DNS propagation. Refer to "certbot --help manual" and the Certbot User Guide.
I have opened an issue on GitHub hoping the author can shine some light into the issue.
The script finally decided to work and add the DNS records to my domain:
Successfully received certificate. Certificate is saved at: /etc/letsencrypt/live/xyz.com/fullchain.pem Key is saved at: /etc/letsencrypt/live/xyz.com/privkey.pem
However, I don't know what I'm supposed to do now. Do I have to manually install the certificate and key in NameSilo's cPanel? If I have to do this manually each time, I don't understand the point of scheduling the issuing/renewal of the certificate...
Since I'm running this on GitLab CI/CD, these files are actually not saved anywhere anyway!
