ok
So I use GateOne to provide me with web based SSH terminal to my home server. for obvious reasons it’s good to have that encrypted. So gateone runs on my server under https on the root
I have a dynamic DNS address pointing to my homesever under the mooo.com domain.
If i can get a certificate for mydomain.mooo.com i can easily configure gateone to use that cert
`Failed authorization procedure. mydomain.mooo.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS S
NI challenge. Found *.protazoa.com
- The following 'urn:acme:error:unauthorized' errors were reported by
the server:
Domains: mydomain.mooo.com
Error: The client lacks sufficient authorization`
Any suggestions about what to do to make this work
PS. I’ve changes the sub domain above for public display
