My organization has a web application written in Java that is hosted on Apache Tomcat (8.5.35) on an Ubuntu 18.04 server. The web application is not a website, it’s a RESTful API. I am working on HTTPS enabling it and someone suggested Let’s Encrypt. I had previously HTTPS enabled it with a self-signed cert but it does throw warnings that we would like to avoid if possible. I am somewhat new to the world of encryption in web technology, however with the self-signed cert I was able to add the cert to a Java Keystore and reference that keystore in the server.xml file and it worked.
Looking through the Getting Started guide with Let’s Encrypt I see it mention virtual hosts and domain names, both of which I am not really sure we have. The server our solution is hosted on is meant to be within the intranet of a customer site behind a firewall. It will be referenced directly by an IP address and so I’m not really sure what the domain would be. In addition we are not using virtual hosts within apache.
So my question is, can we use Let’s Encrypt to HTTPS enable our web application? Can I get the certificate and import it into the Java Keystore like I did the self-signed one or is there another way? Can I use the certbot to maintain the cert or is that option not available in an implementation like this? I would be super grateful for any suggestions or help. I did search the forum and I didn’t see another question quite like this. Apologies if this topic has come up before.
I have root access to the server.
Thanks!
Colin
