Using a Letsencrypt Certificate on a Subdomain
My domain is: admin.quiltinaday.com
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: AWS EC2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.8.0
I have created a new Linux server on AWS that is going to be a subdomain of a Windows server that has a GoDaddy certificate. I have created 2 A records: admin.quiltinaday.com and www.admin.quiltinaday.com that are pointing to the new server. The instructions I saw stated that I need a www record for Letsencrypt. Do I need the www.admin.quiltinaday.com DNS record? Can I create a certificate with letsencrypt for the new server that will not conflict with the Windows server?
Need, no.
It's only useful if you want to use the www 4th level (sub)domain.
The server the DNS IP points to is queried to satisfy the HTTP Challenge. So, if admin subdomain points to your Linux that's where you run Certbot and make the cert for that domain.
Your other server won't know anything about that.
One "server" is not a "subdomain" of another server. The DNS A (and AAAA) records are placeholders for the IP address. These can point to the same server or different ones.
