My domain is: attelann.fr
My sub-domain is : configurateur.attelann.fr
My hosting provider, if applicable, are : OVH / https://www.ovh.com/fr/ and WP Trigone (WPT) https://wptrigone.net/
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes, OVH interface and IPS Config for WPT
I have this problem can you help me ?
Today, my web sites, domain and sub-domain are in OVH with Let’s Encrypt.
Now, I want install the new web site (attleann.fr) on the new host provider (WPT) with Let’s Encrypt, without change the sub-domain and his web site.
In the first host provider (OVH) I have :
In the second host provider (WPT) I have :
Finaly I want :
It’s possible ? Because I did not succeed this morning.
Thank you for your help
Olivier
Hi @OlivierSN
yes, that should be possible. But don't deactivate certificates, that's not required.
What didn't work?
There is a template:
Hi @JuergenAuer
The name of the server did not change … after several minutes / hours
Thank you, I test now.
I did you the result.
Checked your two domain names, they have different ip addresses:
The first ( https://check-your-website.server-daten.de/?q=attelann.fr ):
| Host |
T |
IP-Address |
is auth. |
∑ Queries |
∑ Timeout |
| attelann.fr |
A |
79.137.39.123 |
yes |
1 |
0 |
AAAA |
yes |
| www.attelann.fr |
A |
79.137.39.123 |
yes |
1 |
0 |
AAAA |
2001:41d0:301::23 |
yes |
The second ( https://check-your-website.server-daten.de/?q=configurateur.attelann.fr ):
DNS results are cached, about 6, 12 or 24 hours (max. 48).
Working online tools uses always the authoritative name servers, so they have always the correct result.
Yes it’s normal it’s not the same serveur and IP.
Now it’s almost good
But… i don’t now why I have this result
There is the wrong certificate installed.
Check
certbot certificates
and your vHost to see, which certificate is used.
It’s not the same certificate, because i have separate the two web site on two servers with two Let’s Encrypt… but the domain racine is attleann.fr
It’s not possible for this configuration ?
