I have been using LetsEncrypt certificates for some time, and they've been working fine for the sites that I host under Apache.
I need to create a very lightweight https server in Java, and it appears to be failing during the SSL negotiation. I cloned this system (hoyo.zeetix.com) from its counterpart (byron.zeetix.com). Each is a robust AWS EC2 instance running Linux.
I'm pretty sure that at least part of the problem is revealed in the curl output below. Based on my ssl.conf, it appears that the negotiation is looking in /etc/pki/tls/certs, for something called ca-bundle.crt.
I have not knowingly changed anything in /etc/pki/tls after cloning this instance from byron.zeetix.com. I used certbot to delete the certs for byron.zeetix.com and created new certs for hoyo.zeetix.com. Those all live in the regular place (/etc/letsencrypt/).
I've noticed that two files are (still) identical between hoyo and byron:
/etc/pki/tls/certs/localhost.crt/etc/pki/tls/private/localhost.key
Do I need to do something in /etc/pki/tls so that I can connect to the new https server I'm trying spin up?
I invite the guidance of this community.
My domain is: hoyo.zeetix.com
I ran this command: curl -vvv https://tms.hoyo.zeetix.com:7899/test
[tms@hoyo ~]$ curl -vvv https://tms.hoyo.zeetix.com:7899/test
* Trying 172.30.2.59...
* TCP_NODELAY set
* Connected to tms.hoyo.zeetix.com (172.30.2.59) port 7899 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (IN), TLS handshake, [no content] (0):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to tms.hoyo.zeetix.com:7899
* Closing connection 0
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to tms.hoyo.zeetix.com:7899
My web server is (include version): NA
The operating system my web server runs on is (include version): Rocky Linux (CentOS 8)
My hosting provider, if applicable, is: NA
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.5.0
