Server certificate problems
A little help please as newish to certs and the problems and can not find theanswer here (maybe missed it)
I run a server at server.watchet.net and have run a certbot certificate for the server. However, the server is still looking in etc/ssl/certs for the certificate and I still can not find where it is being called from (not any .conf file as grepped for hours!)
So, I was just going to replace manaully the certificate in the etc/sll/certs folder with a letencrypt one - but - The files I have in this folder are ca-bundle.crt // ca-bundle.trust.crt // localhost.crt - so I guess the localhost.crt is the main file.
My question is how if possible do I use a letsencrypt certificate to replace the .crt file?
Mny thanks
John
UK
Please excuse spelling above
used a mobile phone! No excuse!
don't. you don't need to.
run certbot install --apache
PS
Certs are in etc/pki/tls/private and are localhost.ket // watchetwebdesign.co.uk.csr // watchetwebdesign.co.uk.key
The webdesign is no longer used.
In /etc/pki/tls/certs is symbolic link to the folder in first part of post
Sorry
so confused!
Forget about those.
What command did you run to obtain your Let's Encrypt certificates?
Well, that's a big assumption. I guess your crystal ball works better than mine!
@JRWatchet can you confirm your webserver is Apache? If not, which webserver are you running? Which Linux distribution are we talking about?
(I checked the server response headers :wink:)
Hi
certbot - d server.watchet.net --apache
Centos 7 with full root access
found the link to these files in ssl.conf under /conf.d
Smart! Not 100 %, but probably close enough :stuck_out_tongue:
ok, and the output was?
if you don't recall, run certbot certificates and tell us how many certificates certbot knows about
The server.watchet.net certificates are there but if you use say firefox to view https://server.watchet.net then you will see it is looking at the certs mentioned above as there is a makefile with exactly the same text in it to make a self signed cert - which I do not want!
PS. messages crossed. There are 20 certs on the server all working properly. Ditto for the s.w.n as installed fine and no errors. All there in renewals etc when needed.
Problem is server is looking at these other files instead of reading the virtualhost entry in httpd.conf showing port 443 for ssl
ServerName server.watchet.net DocumentRoot "/var/www/html" DirectoryIndex index.html index.htm index.php index.php4 index.php5
<Directory /var/www/html>
Options +Indexes +IncludesNOEXEC +SymLinksIfOwnerMatch
allow from all
AllowOverride All Options=ExecCGI,Includes,IncludesNOEXEC,Indexes,MultiViews,SymLinksIfOwnerMatch
Require all granted
AddType application/x-httpd-php .php
SSLCertificateFile /etc/letsencrypt/live/server.watchet.net/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/server.watchet.net/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/server.watchet.net/chain.pem
is in httpd.conf
ssl.conf though has
Server Certificate:
Point SSLCertificateFile at a PEM encoded certificate. If
the certificate is encrypted, then you will be prompted for a
pass phrase. Note that a kill -HUP will prompt again. A new
certificate can be generated using the genkey(1) command.
SSLCertificateFile /etc/pki/tls/certs/localhost.crt
Server Private Key:
If the key is not combined with the certificate, use this
directive to point at the key file. Keep in mind that if
you’ve both a RSA and a DSA private key you can configure
both in parallel (to also allow the use of DSA ciphers, etc.)
SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
Server Certificate Chain:
Point SSLCertificateChainFile at a file containing the
concatenation of PEM encoded CA certificates which form the
certificate chain for the server certificate. Alternatively
the referenced file can be the same as SSLCertificateFile
when the CA certificates are directly appended to the server
certificate for convinience.
#SSLCertificateChainFile /etc/pki/tls/certs/server-chain.crt
Certificate Authority (CA):
Set the CA certificate verification path where to find CA
certificates for client authentication or alternatively one
huge file containing all of them (file must be PEM encoded)
#SSLCACertificateFile /etc/pki/tls/certs/ca-bundle.crt
copy/paste missed out the bracketed stuff in httpd.conf
obviouslst starts with IfModule and the virtual host
Please put configuration files between three backticks: ``` before and ``` after.
sssl.conf
‘’’ # Server Certificate:
Server Private Key:
httpd.conf
<VirtualHost 185.41.9.25:443 [fe80::216:3eff:fe6f:40b8]:443>
DocumentRoot “/var/www/html”
allow from all
Require all granted
try again!
allow from all
Require all granted
<VirtualHost 185.41.9.25:80 [fe80::216:3eff:fe6f:40b8]:80>
DocumentRoot /var/www/html
seeems to be missing out brackets etc
so starts with IfModule mod_ssl.c
and after the ssl lines end IfModule end Virtualhost
there is also an end virtual host at the very bottom
forget about ssl.conf too, for this moment.
run apachectl configtest
if that does not complain, systemctl reload apache (or however it’s called on centos, httpd maybe?) don’t do this if the previous command complains, apache will stop.
Already tried a lot of different configurations, some broke apache some didn’t but still did not sort anything out (I run an ftp client the root and edit files that way as easier than vi etc. ) then constantly restart apache to see what works and what doesn’t.
All is happy at the moment but Dovecott was using this fake cert so managed to reconfigure that to use the main server.watchet.net cert so that bit solved.
However, the https:// to the server still shows accessing the cert in the pki folder and grepping everywhere the ONLY file that refers to that cert is the ssl.conf file.
Somehow I have to creat the pair of certs for this location so that the server and localhost are served
john
You started from this document here, right?
https://httpd.apache.org/docs/2.4/ssl/ssl_howto.html
(and for apache 2.2 https://httpd.apache.org/docs/2.2/ssl/ssl_howto.html)
