glpi.cefim.eu
certbot
1: glpi.cefim.eu
blank to select all options shown (Enter ‘c’ to cancel):1
tls-sni-01 challenge for glpi.cefim.eu
/usr/lib/python2.7/dist-packages/OpenSSL/rand.py:58: UserWarning: implicit cast from 'char ’ to a different pointer type: will be forbidden in the future (check that the types are as you expect; use an explicit ffi.cast() if they are correct)
** result_code = _lib.RAND_bytes(result_buffer, num_bytes)*
Waiting for verification…
Failed authorization procedure. glpi.cefim.eu (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to 52.17.128.132:443 for tls-sni-01 challenge
** - The following errors were reported by the server:**
** Domain: glpi.cefim.eu**
** Type: connection**
** Detail: Failed to connect to 52.17.128.132:443 for tls-sni-01**
** challenge**
** To fix these errors, please make sure that your domain name was**
** entered correctly and the DNS A record(s) for that domain**
** contain(s) the right IP address. Additionally, please check that**
** your computer has a publicly routable IP address and that no**
** firewalls are preventing the server from communicating with the**
** client. If you’re using the webroot plugin, you should also verify**
** that you are serving files from the webroot path you provided.**
Server version: Apache/2.4.10 (Debian)
Linux CertBot 3.16.0-4-686-pae #1 SMP Debian 3.16.43-2 (2017-04-30) i686 GNU/Linux
AWS
YES
NO
I just saw on the firewall rules that the port 443 isn’t close. Please help and tell me if you need more informations.
Thanks
