URL is not showing secured after installing CertBot
My domain is: reactler.com
I ran this command: sudo certbot certonly --standalone
It produced this output: successfully configured
My web server is (include version): PRETTY_NAME="Ubuntu 24.04.1 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04.1 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="Bugs : Ubuntu"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logo
My hosting provider, if applicable, is: Azure
After the successful installation of certbot, the site did not show as secure.
There's no reason to expect it would. You told certbot to obtain a cert, not to configure your web server (whatever it is--which isn't Ubuntu) to use that cert to serve HTTPS. You'll need to do that.
This option does exactly that, as Dan already said: you only get the cert. The rest (i.e.: actually installing/using the cert) is up to the user.
By the way:
Is there a specific reason why you're using the standalone authenticator when you have a perfectly fine webserver Apache running on that host, apparently? Which was probably also the correct answer to the "My webserver is" question. "Ubuntu" was the answer to the "operating system" question :wink:
Usually the --apache authenticator works just fine which is also an installer plugin, if you want to let Certbot do all the work.. No need for the --standalone, which is quite a hassle if you already have a webserver running.
To be honest, it sounds like you have been following some guide in a misguided manner, not actually knowing what you're doing. (And I don't mean this in a mean way [it's Christmas after all], just being honest here, trying to understand the "how" and "why" of your actions..)
There are multiple systems involved. Other volunteers also see prior thread from OP here:
Notably the DNS is pointing to Hostinger still
@MikeMcQ That's the .in TLD, the .com TLD seems to be served by ns{1,2}.dns-parking.com. and is hosted on an IP address from MS.
@rajagopal Also, please don't forcibly "renew & replace" (the option you chose) the certificate if the certificate itself is perfectly fine. There is absolutely no need to re-issue a certificate if issuance was not the problem to begin with.
Good point. But, they described the .in domain as being Azure as well as showing the same Ubuntu info in that other thread. Still think it's worth keeping in mind their various efforts.
From around the world HTTPS get "Connection refused" Permanent link to this check report
Tough to be secure without HTTPS (i.e. Port 443) accessible.
Port 443 is closed
$ nmap -Pn -p80,443 reactler.com
Starting Nmap 7.93 ( https://nmap.org ) at 2024-12-26 08:28 PST
Nmap scan report for reactler.com (4.186.62.206)
Host is up (0.21s latency).
PORT    STATE  SERVICE
80/tcp  open   http
443/tcp closed https
Nmap done: 1 IP address (1 host up) scanned in 0.43 seconds
Edit
And here is what I find for DNS
For reactler.com
And reactler.in
The reactler.com server has already allowed with below ng.
I am new to this task. So anyone provide me the steps what to do next after got issued the cert
Does Let’s Encrypt issue certificates for anything other than SSL/TLS for websites?
Assuming that the issue here is for web server, I still I see Port 443 closed thus access for HTTPS is not possible on the default port.
Starting Nmap 7.93 ( https://nmap.org ) at 2024-12-26 20:02 PST
PORT    STATE  SERVICE
80/tcp  open   http
Nmap done: 1 IP address (1 host up) scanned in 0.39 seconds
All routers and firewalls between the server in question and the public internet need to Allow access through.
Here details on Apache can be found in documentation and forums:
Probably because they have not yet configured their Apache server for HTTPS on port 443 :slight_smile:
You see Closed, not Filtered.
Below is good advice.
ufw 443 is now enabled, but still facing same issue,
I was reconfigured with apache,
then also I am not getting the site secured,
Please show output of this
sudo apache2ctl -t -D DUMP_VHOSTS
I tried using apache insttalation but i'ts not completing the installation properly, ended with subprocess error.
The separate rule you have shown is unnecessary. Apache Full already covers both HTTP on 80 and HTTPS on 443.
