Urgent certbot does not update due DNS issue
certbot renewal
And
dig @8.8.8.8 acme-v1.letsencrypt.org (from several servers)
Attempting to renew cert (xxxx) from /etc/letsencrypt/renewal/nwh.c
Xxxx.de.conf produced an unexpected error: ("bad handshake: Error([('SSL ro
utines', 'tls_process_server_certificate', 'certificate verify failed')],)",)
. Skipping.
and
<<>> DiG 9.10.3-P4-Debian <<>> @8.8.8.8 acme-v1.api.letsencrypt.org
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 51764
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;acme-v1.api.letsencrypt.org. IN A
;; AUTHORITY SECTION:
letsencrypt.org. 1800 IN SOA owen.ns.cloudflare.com. dns.c
loudflare.com. 2261477481 10000 2400 604800 3600
;; Query time: 8 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Sat Nov 06 08:05:15 CET 2021
;; MSG SIZE rcvd: 118
My web server is (include version): Apache 2 2 .4.25
The operating system my web server runs on is (include version): debian 9.13
My hosting provider, if applicable, is: hetzner
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.28.0
Welcome to the Let's Encrypt Community :slightly_smiling_face:
Your certbot version is ancient and ACMEv1 is obsolete. You need to update to an ACMEv2 client.
Actually...
Should be capable of using ACMEv2 protocol.
See:
Certbot 0.22.0 Release with ACMEv2 and Wildcard Support - Client dev - Let's Encrypt Community Support (letsencrypt.org)
The problem may lie in that it already issued a cert via ACMEv1 and now may need to be instructed to use ACMEv2.
Not to say that I recommend using such an old version.
Quite the opposite; There are many reasons to keep this and all software up to date.
Quite true, @rg305.
Simply changing the server line in the renewal configuration file from https://acme-v01.api.letsencrypt.org/directory to https://acme-v02.api.letsencrypt.org/directory might be sufficient.
Although the bad handshake seems to imply that OpenSSL may be having issue too...
Not enough of the LE logs are shown to understand what went wrong.
Unfortunately not. as I had the https://acme-v02.api.letsencrypt.org/directory already configured.
And i still assume its not an issue of the certbot but more a DNS issue.
I tried several dns resolver all failed to resolve an ip address for acme-v2
Please show the outputs of:
curl -Iv https://acme-v02.api.letsencrypt.org/
openssl version
But you only showed ACMEv1 DNS requests.
Ah...
DST Root CA X3 expiration complications possibly.
I would be surprised if this even responds:
I always thought it was only this:
Change that to v02.
*   Trying 172.65.32.248...
* TCP_NODELAY set
* Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS alert, Server hello (2):
* SSL certificate problem: certificate has expired
* Curl_http_done: called premature == 1
* stopped the pause stream!
* Closing connection 0
curl: (60) SSL certificate problem: certificate has expired
More details here: https://curl.haxx.se/docs/sslcerts.html
openssl: OpenSSL 1.1.1i 8 Dec 2020
# dig @8.8.8.8 acme-v2.api.letsencrypt.org
; <<>> DiG 9.10.3-P4-Debian <<>> @8.8.8.8 acme-v2.api.letsencrypt.org
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 48229
;acme-v2.api.letsencrypt.org.   IN      A
letsencrypt.org.        1800    IN      SOA     owen.ns.cloudflare.com. dns.cloudflare.com. 2261477481 10000 2400 604800 3600
;; Query time: 9 msec
;; WHEN: Sat Nov 06 08:30:58 CET 2021
OpenSSL looks good enough.
You may need to update your ca-certificates
These have no A records:
This does:
I think the same with DST Root CA X3 expiration.
How can I resolve this?
That's where @rg305 is headed. He has been the master of solving such here. :grin:
acme-v02.api.letsencrypt.org is reachable and seem to work.
Anyway I have updated to certbot 1.21. and it just worked well, too
So it seems that certbot 1.21 does not use the cli.ini located in /etc/letsencrypt/ anymore?
UPDATE: certbot 1.21 uses the cli.ini. And during the installation it has corrected the line
https://certbot.eff.org/docs/using.html#configuration-file
Anywho... this might also be useful:
But in this case, the acme api doesn't use the expired cert.
[fixing tomorrows problems today - LOL]
Be very careful if you keep using cli.ini. I've only ever really found it useful for coordinating docker containers.
