My domain is: matchett-tech.com
Ran the container:
HTTP: 180
HTTPS:1443
entered all correct details
nginx (not sure)
Yes
Using Unraid 6.8.1
The images were from somewhere else. You’re reply has given no help whatsoever.
I know port 80 is being blocked, that’s the whole issue I’m trying to fix. I’m trying to open both port 80 and 443. I have unblocked them from my ISP toolbox and they are still showing as blocked.
I have already said that port blocking has been switched off. I have toggled it multiple times, and yes I waited a few hours between turning it on and then back off again.
Seems like you’re ignoring what I said originally. Everything that should be set is set, and port 80 is still blocked.
