Unraid Docker Certbot Firewall Issue
My domain is: Traxson.net
I ran this command: Request New SSL Certificate
It produced this output: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
My web server is (include version): Swag (Latest)
The operating system my web server runs on is (include version): Unraid 6.9.2
My hosting provider, if applicable, is: Cloudflare
I am running Nginx Proxy Manager on an Unraid server, trying to Proxy different dockers and a website. Using PFsense for a router /firewall,
Everything is port Forwarded correctly and Rules for port 80 and 443 are set to pass,
Using the built in Traceroute in PFsense I know my NPM Docker is accepting traffic on port 8080 and 4443 and the router is set to forward all incoming traffic from 80 -> 8080 and 443 -> 4443
I cant find any reason why im getting a firewall error like this with Certbot.
Hi @Jomigo, welcome to the LE community forum :slight_smile:
There is one thing that might make this... complicated.
  1. Cloudflare
At a minimum, CF will likely be redirecting HTTP to HTTPS.
So if the challenge request is being expected in HTTP, it might not even be heard (there).
I would start by reviewing the webserver config, with:
sudo nginx -T
And also review the LE log file.
okay, not sure exactly what i should be looking for in my Sudo Nginx -T tho,
after some tinkering this is the lastest error messages im getting now
2021-09-17 20:54:07,183:ERROR:certbot._internal.log:An unexpected error occurred:
2021-09-17 20:54:07,184:ERROR:certbot._internal.log:requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x14f259d554c0>: Failed to establish a new connection: [Errno -3] Try again'))
Then, can you show it here so that others may look for you?
Here is the log file after the most recent attempt to get a letencrypt Cert. Hopefully this is what your asking for
2021-09-19 15:40:12,490:DEBUG:certbot._internal.main:certbot version: 1.19.0
2021-09-19 15:40:12,490:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2021-09-19 15:40:12,490:DEBUG:certbot._internal.main:Arguments: ['--non-interactive', '--config', '/etc/letsencrypt.ini', '--cert-name', 'npm-32', '--agree-tos', '--authenticator', 'webroot', '--email', 'traxsoninc@outlook.com', '--preferred-challenges', 'dns,http', '--domains', 'bitwarden.traxson.net']
2021-09-19 15:40:12,490:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#dns-cloudflare,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2021-09-19 15:40:12,622:DEBUG:certbot._internal.log:Root logging level set at 30
2021-09-19 15:40:12,624:DEBUG:certbot._internal.plugins.selection:Requested authenticator webroot and installer None
2021-09-19 15:40:12,631:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * webroot
Description: Place files in webroot directory
Interfaces: Authenticator, Plugin
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Initialized: <certbot._internal.plugins.webroot.Authenticator object at 0x1462a43e8b80>
Prep: True
2021-09-19 15:40:12,631:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.webroot.Authenticator object at 0x1462a43e8b80> and installer None
2021-09-19 15:40:12,632:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator webroot, Installer None
2021-09-19 15:40:12,639:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/201308930', new_authzr_uri=None, terms_of_service=None), f2a050da278cafcdd81ddfb7fb942486, Meta(creation_dt=datetime.datetime(2021, 9, 15, 5, 57, 53, tzinfo=<UTC>), creation_host='7a6b0d3039bf', register_to_eff=None))>
2021-09-19 15:40:12,640:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2021-09-19 15:40:12,662:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2021-09-19 15:40:13,012:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 658
2021-09-19 15:40:13,013:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 19 Sep 2021 20:40:12 GMT
Content-Length: 658
X-Frame-Options: DENY
  "meta": {
    "caaIdentities": [
      "letsencrypt.org"
    "termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
  "revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert",
  "x24Z0Zyk4ks": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417"
2021-09-19 15:40:13,014:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for bitwarden.traxson.net
2021-09-19 15:40:13,016:DEBUG:certbot.crypto_util:Generating ECDSA key (2048 bits): /etc/letsencrypt/keys/0000_key-certbot.pem
2021-09-19 15:40:13,051:DEBUG:certbot.crypto_util:Creating CSR: /etc/letsencrypt/csr/0000_csr-certbot.pem
2021-09-19 15:40:13,052:DEBUG:acme.client:Requesting fresh nonce
2021-09-19 15:40:13,052:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2021-09-19 15:40:13,112:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2021-09-19 15:40:13,113:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 19 Sep 2021 20:40:13 GMT
Replay-Nonce: 0001vzwr1B0Nu6bNEDseroLNQw7-JSddEuBUF7Rf5Vt1V_g
2021-09-19 15:40:13,114:DEBUG:acme.client:Storing nonce: 0001vzwr1B0Nu6bNEDseroLNQw7-JSddEuBUF7Rf5Vt1V_g
2021-09-19 15:40:13,114:DEBUG:acme.client:JWS payload:
b'{\n  "identifiers": [\n    {\n      "type": "dns",\n      "value": "bitwarden.traxson.net"\n    }\n  ]\n}'
2021-09-19 15:40:13,116:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjAxMzA4OTMwIiwgIm5vbmNlIjogIjAwMDF2endyMUIwTnU2Yk5FRHNlcm9MTlF3Ny1KU2RkRXVCVUY3UmY1VnQxVl9nIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIifQ",
  "signature": "M4zHl3G3jKiSJTYH7wvOKjJig6dcnGaMOBGTSFb7PpR68kcrZYOnVRwlC3ClFgb9Q5F0HCeTyiaK9mF3AuR8LEmSUkYzYAd_bYqB_dFGDt2FsNKpf0SEpR0ddb_J6xccpU1umHriQgGyEeKcUD-ind2iC5RYnWoT1x--EU_ro7Bm4s1xHE7c7hzKzlGy1x8Avt2f65Fl9i5gltXE63gql1sUGpj_gf0o_91DX6UsENBbgW2lZKZ9Sc6AM7mfx3hlOX9oyknDgjX_bah2HPM_-N-OO4eagYqagVnv2WBx9I_iUPMwA4HMY0Cw5d9nWRAB9B7qDqiHqIOGq3Rh5WKwiA",
  "payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImJpdHdhcmRlbi50cmF4c29uLm5ldCIKICAgIH0KICBdCn0"
2021-09-19 15:40:13,217:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 344
2021-09-19 15:40:13,218:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 344
Boulder-Requester: 201308930
Location: https://acme-v02.api.letsencrypt.org/acme/order/201308930/25709860080
Replay-Nonce: 0001TluIkqDpqA3VhWc2UokmkZbeYKn0qEpDho-DagPv7VU
  "status": "pending",
  "expires": "2021-09-26T20:40:13Z",
  "identifiers": [
      "type": "dns",
  "authorizations": [
    "https://acme-v02.api.letsencrypt.org/acme/authz-v3/32528097390"
  "finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/201308930/25709860080"
2021-09-19 15:40:13,218:DEBUG:acme.client:Storing nonce: 0001TluIkqDpqA3VhWc2UokmkZbeYKn0qEpDho-DagPv7VU
2021-09-19 15:40:13,219:DEBUG:acme.client:JWS payload:
b''
2021-09-19 15:40:13,221:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/32528097390:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjAxMzA4OTMwIiwgIm5vbmNlIjogIjAwMDFUbHVJa3FEcHFBM1ZoV2MyVW9rbWtaYmVZS24wcUVwRGhvLURhZ1B2N1ZVIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8zMjUyODA5NzM5MCJ9",
  "signature": "H4QwjT8XHamepY9gTHkJcfbpY95VahB2tdBNmEbYsJ15DFPo4vUewvBzPIIXcKmFZtnSviyqhB9jAKw6phmqyZUQrbALmEAAKDpW6ZBU5bWl22K0HACylV9p_irQUptichSG8cQXI3SlsrfB62bgK16Fh57j3BQevJVs0yIEhuEZiKQXvhOO-rQ1o18Zm2JhSigZvHtH3r6s5fTdzlOP9LPTaZBjAMUBWzo-qOEFEfp4XuPbY9RIM_XS-oLykSWVN74dcnEBZVrSX70B65txdcIGdrMJDQhHmMkTXdpzUinkI-k4W9UWzCBocfZGRK9mXy1R89XKuPSVqDkQC5qaTQ",
  "payload": ""
2021-09-19 15:40:13,311:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/32528097390 HTTP/1.1" 200 802
2021-09-19 15:40:13,312:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 802
Replay-Nonce: 0002lkWAHcrT6_hzJdrf-j-tRasLa8ou81h0QuxW1sDyC7g
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/32528097390/lPJIvQ",
      "token": "Z2DZTUcIfRgZiBCc35O7PFITgRqVI_jz66Fm_VO0ZbM"
      "type": "dns-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/32528097390/ZLnMTQ",
      "type": "tls-alpn-01",
      "url": "https://acme-v02.api.letsencrypt.org/acme/chall-v3/32528097390/rpN-LA",
2021-09-19 15:40:13,313:DEBUG:acme.client:Storing nonce: 0002lkWAHcrT6_hzJdrf-j-tRasLa8ou81h0QuxW1sDyC7g
2021-09-19 15:40:13,314:INFO:certbot._internal.auth_handler:Performing the following challenges:
2021-09-19 15:40:13,314:INFO:certbot._internal.auth_handler:http-01 challenge for bitwarden.traxson.net
2021-09-19 15:40:13,314:INFO:certbot._internal.plugins.webroot:Using the webroot path /data/letsencrypt-acme-challenge for all unmatched domains.
2021-09-19 15:40:13,315:DEBUG:certbot._internal.plugins.webroot:Creating root challenges validation dir at /data/letsencrypt-acme-challenge/.well-known/acme-challenge
2021-09-19 15:40:13,317:DEBUG:certbot._internal.plugins.webroot:Attempting to save validation to /data/letsencrypt-acme-challenge/.well-known/acme-challenge/Z2DZTUcIfRgZiBCc35O7PFITgRqVI_jz66Fm_VO0ZbM
2021-09-19 15:40:13,318:DEBUG:acme.client:JWS payload:
b'{}'
2021-09-19 15:40:13,319:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/32528097390/lPJIvQ:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjAxMzA4OTMwIiwgIm5vbmNlIjogIjAwMDJsa1dBSGNyVDZfaHpKZHJmLWotdFJhc0xhOG91ODFoMFF1eFcxc0R5QzdnIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My8zMjUyODA5NzM5MC9sUEpJdlEifQ",
  "signature": "GpW0YIzN3suGXMfMvOQRdgEWv5vZLqg8bNa4N_h15927g3A9Syrvy30DF3kY0yi1kBCEXlVgILbRxGGlONJhWKK_A3qPMQjv73JQp7Dd5pSM-Ofg8e2-FprV6o2ajzv8HRymUHQfHgORq9F9ajfNjjGinU7Ca38zJT3E0mg6F4W4JYD13UF8Z9XLJeaZSTTRnOL8taQiNmdc7rvPr77vl_AC37YKgMDPdyy-EurdhI-RBqyZc8BG3-G_sEU0kcnCriH5-7LVp9CInlJQtxjLOTjyvbi-7UdNlBfjUY-o6wXKlqeKNkaXldGcDFVTaj5gXNSz291v0aoOV4fVS9UBow",
  "payload": "e30"
2021-09-19 15:40:13,413:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall-v3/32528097390/lPJIvQ HTTP/1.1" 200 186
2021-09-19 15:40:13,414:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 186
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz-v3/32528097390>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall-v3/32528097390/lPJIvQ
Replay-Nonce: 0002DFB80-BV79jL1dNmbnVg2GC_p11CXoNmynI9yq-rQp4
  "type": "http-01",
2021-09-19 15:40:13,414:DEBUG:acme.client:Storing nonce: 0002DFB80-BV79jL1dNmbnVg2GC_p11CXoNmynI9yq-rQp4
2021-09-19 15:40:13,415:INFO:certbot._internal.auth_handler:Waiting for verification...
2021-09-19 15:40:14,417:DEBUG:acme.client:JWS payload:
b''
2021-09-19 15:40:14,419:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/32528097390:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjAxMzA4OTMwIiwgIm5vbmNlIjogIjAwMDJERkI4MC1CVjc5akwxZE5tYm5WZzJHQ19wMTFDWG9ObXluSTl5cS1yUXA0IiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8zMjUyODA5NzM5MCJ9",
  "signature": "v-bMRj58nMQx-FjXkieirD2QEE89ajIEVHdZRjNfUg8Yo18WgOT5DjwkvqxLN6DZJiZh-aIA9eqKOKRNrlv7iailfH0VRlnSpol_lmzMGbCHvzkePeiS8CsQ0hn4EKUwABKypjCe2KuCs9skIvmqvaoHSvD-P46yfYF0T3jFLSKImpZEj_LXgy0BYQ7vuVRebjAtzmiSxIuDN5kfHjE6DJLBdNr6wjQzk4hUxKA4fiTUwJkt9ZGK2X3B5QKGvabRN5ePjfM5olll0fA2zSlbzhDdD3APVtuKtg2iY4anCm8nymAomJPzXWnNYDr6VZ0NNmzpAK6chxHPoJUNKwM2ew",
  "payload": ""
2021-09-19 15:40:14,489:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/32528097390 HTTP/1.1" 200 802
2021-09-19 15:40:14,490:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 19 Sep 2021 20:40:14 GMT
Content-Length: 802
Replay-Nonce: 0002EHUl_O9AKdtnaBoQBmliuXPxAUpQyPIU6qJFij4BVM4
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "type": "dns-01",
2021-09-19 15:40:14,490:DEBUG:acme.client:Storing nonce: 0002EHUl_O9AKdtnaBoQBmliuXPxAUpQyPIU6qJFij4BVM4
2021-09-19 15:40:17,494:DEBUG:acme.client:JWS payload:
b''
2021-09-19 15:40:17,496:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/32528097390:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjAxMzA4OTMwIiwgIm5vbmNlIjogIjAwMDJFSFVsX085QUtkdG5hQm9RQm1saXVYUHhBVXBReVBJVTZxSkZpajRCVk00IiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8zMjUyODA5NzM5MCJ9",
  "signature": "Rerrf0Z3q8BvBmkQVq1z8jzY1GaNoro6lpfPDM2GF0-3MfMAK8UPrWimlLrAfv12jPfEz63IxM9HmbIzaiupA7Sa1fDh-vbipyknbwzm1TYgqfjRdNVafWrD7dom03pDLXBM_TJlqmN0YhEI8BSDIEEDDXLt-AI8Orw-HpABDSBbsuxuBE9GKXxXlAx6Hue7uJR0dfO98rfvb6vqogEvyH0FPga-P4po7IEACIgOOhyuyJJ-DkZDUnaKcpfSgkMljhgFyla0mtgMEAWRuh3IVsCnkwj0DpHwdRAR5yD8lN853MrbcLWNq3sWRw1AcnRBClN6bFzHsJOSctgYi40shw",
  "payload": ""
2021-09-19 15:40:17,570:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/32528097390 HTTP/1.1" 200 802
2021-09-19 15:40:17,571:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 19 Sep 2021 20:40:17 GMT
Content-Length: 802
Replay-Nonce: 0001HGz3n0PPfKui6roT0UA7KQNJj_hIRAnb--a4HBbh-og
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "type": "dns-01",
2021-09-19 15:40:17,571:DEBUG:acme.client:Storing nonce: 0001HGz3n0PPfKui6roT0UA7KQNJj_hIRAnb--a4HBbh-og
2021-09-19 15:40:20,575:DEBUG:acme.client:JWS payload:
b''
2021-09-19 15:40:20,578:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/32528097390:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjAxMzA4OTMwIiwgIm5vbmNlIjogIjAwMDFIR3ozbjBQUGZLdWk2cm9UMFVBN0tRTkpqX2hJUkFuYi0tYTRIQmJoLW9nIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8zMjUyODA5NzM5MCJ9",
  "signature": "bcy0ecHcIwwCRotynXm3l5m2O4iGSrgZ_JYhhMdDTu3kbqfyoDqg_KdYlmCcdl1AdyoW-8v4SpZOErZyCw4ifSG6oRUc62VLitEIlbW7WXmV8pbbyPg2b-0vYIPLBKJB8nQIHbMdJYcMjWTdmKlYqhNqFlGeAL8dk_7EEML2Ag0B7pN3ksSuyyzlY0izLQThHf-MtY7gOfE-6X7hXX3CTiM13XBjJ7JsMpaOcXj-rkxWHUOA3YVOGk0lzhgO5-De8WU3cMu0b2e3pJDdNwIL2_A-AH3lrgtMQSwM6vJqmbsHzy2Lr2RU3rNeuUWTHtbCKH4-hqUkGkJIzi2-u3mEvQ",
  "payload": ""
2021-09-19 15:40:20,653:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/32528097390 HTTP/1.1" 200 802
2021-09-19 15:40:20,654:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 19 Sep 2021 20:40:20 GMT
Content-Length: 802
Replay-Nonce: 0001XIaZwp6LGLgvqsdABWS3NrCpjMqqY2WizQl3Mn0iYxg
  "identifier": {
    "type": "dns",
  "challenges": [
      "type": "http-01",
      "type": "dns-01",
2021-09-19 15:40:20,655:DEBUG:acme.client:Storing nonce: 0001XIaZwp6LGLgvqsdABWS3NrCpjMqqY2WizQl3Mn0iYxg
2021-09-19 15:40:23,659:DEBUG:acme.client:JWS payload:
b''
2021-09-19 15:40:23,662:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/32528097390:
  "protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMjAxMzA4OTMwIiwgIm5vbmNlIjogIjAwMDFYSWFad3A2TEdMZ3Zxc2RBQldTM05yQ3BqTXFxWTJXaXpRbDNNbjBpWXhnIiwgInVybCI6ICJodHRwczovL2FjbWUtdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My8zMjUyODA5NzM5MCJ9",
  "signature": "dJb3QMsWHkHYtuYlNVd8lSzw9wdL1Gv3s7mpjwYU72eybMndBAeZaivWJXcytJn1k6Pfdll3TjXpjdHiPHX9xH5TzY9yCr_pV3ZjzfuPOBsCNNV5xXDnwkluLEj5JdcsXI15a1ExR4JDkwOLPVqRHm15tSNy5P8FCAu35d4vIiJJDpb43GVrhNCUJgkH800kCC1J_jTl3TLZxTpYgUVH0KyDfQnXIzigQHJJTjOe7tTjQzt1qn0BY1yDY7yXCkOSHK8rDs7CGHPi4FQOFiBQGPX053DEExLepXJhL8XFHRiNBOPsuOw5hbWmyOaXEiIIcT4ePgfojaNs5yjobmqLtg",
  "payload": ""
2021-09-19 15:40:23,733:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz-v3/32528097390 HTTP/1.1" 200 1068
2021-09-19 15:40:23,734:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Sun, 19 Sep 2021 20:40:23 GMT
Content-Length: 1068
Replay-Nonce: 0002CDUlmBpMiQak5tNManaQsFiEAE-SZpIWhj9Q2LIuBQw
  "identifier": {
    "type": "dns",
  "status": "invalid",
  "challenges": [
      "type": "http-01",
      "error": {
        "type": "urn:ietf:params:acme:error:connection",
        "detail": "Fetching http://bitwarden.traxson.net/.well-known/acme-challenge/Z2DZTUcIfRgZiBCc35O7PFITgRqVI_jz66Fm_VO0ZbM: Timeout during connect (likely firewall problem)",
        "status": 400
      "token": "Z2DZTUcIfRgZiBCc35O7PFITgRqVI_jz66Fm_VO0ZbM",
      "validationRecord": [
          "url": "http://bitwarden.traxson.net/.well-known/acme-challenge/Z2DZTUcIfRgZiBCc35O7PFITgRqVI_jz66Fm_VO0ZbM",
          "hostname": "bitwarden.traxson.net",
          "port": "80",
          "addressesResolved": [
            "98.168.242.228"
          "addressUsed": "98.168.242.228"
      "validated": "2021-09-19T20:40:13Z"
2021-09-19 15:40:23,735:DEBUG:acme.client:Storing nonce: 0002CDUlmBpMiQak5tNManaQsFiEAE-SZpIWhj9Q2LIuBQw
2021-09-19 15:40:23,735:INFO:certbot._internal.auth_handler:Challenge failed for domain bitwarden.traxson.net
2021-09-19 15:40:23,736:INFO:certbot._internal.auth_handler:http-01 challenge for bitwarden.traxson.net
2021-09-19 15:40:23,736:DEBUG:certbot._internal.display.obj:Notifying user:
  Domain: bitwarden.traxson.net
  Type:   connection
  Detail: Fetching http://bitwarden.traxson.net/.well-known/acme-challenge/Z2DZTUcIfRgZiBCc35O7PFITgRqVI_jz66Fm_VO0ZbM: Timeout during connect (likely firewall problem)
2021-09-19 15:40:23,737:DEBUG:certbot._internal.error_handler:Encountered exception:
  File "/usr/lib/python3.8/site-packages/certbot/_internal/auth_handler.py", line 90, in handle_authorizations
  File "/usr/lib/python3.8/site-packages/certbot/_internal/auth_handler.py", line 178, in _poll_authorizations
2021-09-19 15:40:23,737:DEBUG:certbot._internal.error_handler:Calling registered functions
2021-09-19 15:40:23,738:INFO:certbot._internal.auth_handler:Cleaning up challenges
2021-09-19 15:40:23,738:DEBUG:certbot._internal.plugins.webroot:Removing /data/letsencrypt-acme-challenge/.well-known/acme-challenge/Z2DZTUcIfRgZiBCc35O7PFITgRqVI_jz66Fm_VO0ZbM
2021-09-19 15:40:23,738:DEBUG:certbot._internal.plugins.webroot:All challenges cleaned up
2021-09-19 15:40:23,739:DEBUG:certbot._internal.log:Exiting abnormally:
  File "/usr/bin/certbot", line 8, in <module>
    sys.exit(main())
  File "/usr/lib/python3.8/site-packages/certbot/main.py", line 15, in main
  File "/usr/lib/python3.8/site-packages/certbot/_internal/main.py", line 1572, in main
  File "/usr/lib/python3.8/site-packages/certbot/_internal/main.py", line 1432, in certonly
    lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
  File "/usr/lib/python3.8/site-packages/certbot/_internal/main.py", line 133, in _get_and_save_cert
  File "/usr/lib/python3.8/site-packages/certbot/_internal/client.py", line 454, in obtain_and_enroll_certificate
  File "/usr/lib/python3.8/site-packages/certbot/_internal/client.py", line 384, in obtain_certificate
  File "/usr/lib/python3.8/site-packages/certbot/_internal/client.py", line 434, in _get_order_and_authorizations
2021-09-19 15:40:23,741:ERROR:certbot._internal.log:Some challenges have failed.
That all boils down to this:
Which has as its' primary (possibly only) problem:
That seems to indicate that port 80 (HTTP) is unable to reach your system.
You must have a functional HTTP site before you can secure it (via HTTP authentication).
thats the part i dont fully understand because i have all my port forwards set right on my Pfsense router, but you are correct something is still blocking it, i should be able to get to the nginx basic congratulations page if i just enter my basic IP address in the adress bar of any web browser but i can not
Just adding a tidbit ... I can reach bitwarden.traxson.net using port 443. curl says it is a self-signed cert but at least it reached bitwarden. I timeout trying port 80 just like you (and Cloudflare).
This puts the focus purely on port 80. I am new here but have seen a couple cases where the internet service provider blocked that port - could that be possible with your cox connection? Mind, this is very speculative on my part.
Here was my curl to 443:
curl -v https://bitwarden.traxson.net
*   Trying 98.168.242.228:443...
* Connected to bitwarden.traxson.net (98.168.242.228) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*  CAfile: /etc/pki/tls/certs/ca-bundle.crt
*  CApath: none
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: self signed certificate
* Closing connection 0
curl: (60) SSL certificate problem: self signed certificate
More details here: https://curl.se/docs/sslcerts.html
As noted, a similar request using http just times out.
Cox specifically documents that they block port 80 on residential connections.
i just talked to cox and they confirmed that they are not blocking any ports to my network.
I especially confirmed that port 80 and 443 was not blocked to my house
You said if all was working right you should see a 'Congrats' page. When I used curl to try port 443 I got an empty response - not a congrats page.
You can use your browser to see this too if you prefer
https://98.168.242.228
My browser issued a warning about 'unsafe cert' but we know that is your self-signed cert (from my prior curl) so we can ignore that helpful warning in this special case. My browser then said 'empty response' - same as if I did curl -k (target)
It seems to me if you could get your expected Congrats response thru 443 it might give a clue as to port 80. You have a number of 'moving parts' (unraid, docker, nginx, pfsense) to evaluate - the more clues the better.
so then it has to be something with my firewall blocking it? I use PFsense and I port forward port 80 and 443 the same as all the other ports for my game servers and stuff & they all work just fine. maybe I need to have someone take a look at my router and see if there is anything messed up with it.
If your router configuration for 80 and 443 are identical, and 443 works but 80 does not, and you're on a residential Cox connection, then my guess would be that the documentation page from Cox that I linked is correct (that they do in fact block port 80), and that whomever you spoke with at Cox was misinformed. There are a lot of conditions I put in that sentence, though.
