Creating certs in a docker container and copying to a reverse proxy, worked. Once.
Now I can no longer generate certs and am presented with
"Let's Encrypt - Portal",
"status": 429
as a link unpause my acccount.
First thought is I am copying too little or too much.
Your account becomes paused when you make a very large number of failed requests over a sustained period for a specific identifier (domain name). The unpause URL shows a page where you can unpause that account / identifier combination. That URL looks normal to me.
Are you asking why you got paused? Because if you don't think you are making lots of failed requests we would like more info to help you debug that. The number of failures needed before getting paused is very large as described here: Rate Limits - Let's Encrypt
Below is the questionnaire we'll need answers to for further debugging
Thanks for the reply. I found many letsencrypt log files that indicate 1 or 2 attempts per day. Clearly I must look into this more as it appear to be on my end.
Two questions - I recently allowed a couple of domains to expire, but did not alter any config files. Bad dog?
Why does the URL not work, if I copied and applied it correctly.
I must beg infirmity of years and health, and stop for tonight.
When I click the link you provided it takes me to the Let's Encrypt unpause page. What do you see when you click that?
Yes, that would cause a failure. You cannot request a cert for a domain that no longer works.
You can see from the Let's Encrypt page about that rate limit that at 2 failures per day it would take over 3 years before you were paused I see you got a cert for the domain on the unpause page on April 12. So, you would have to be failing about once every hour every day for the past 2 months, for example.
That's strange. You even get that just from clicking the link in your first post? Because I get this (just the top part of page - the lower part explains the options)
Yes, that is part of the json format for the entire response. The URL is just one part of that. Let us know if you need help with restoring your function. And try to find what may have caused so many failed requests.
