'unknown CA' after domain problems had been fixed (by my hoster)
Domain: acegames.de
OS: Debain8 on Linux Vserver
Hoster: Kramer Betriebs GmbH
Web-Server: apache2
ControlPanel: no
SSH: Yes
Working Mailserver: yes ( Postfix+dovecot)
How: Using Ajax Request in php to make file mail_send.php send an email via swiftmailer with tls encryption
SysLog:
SL3 alert read:fatal:unknown CA
SSL_accept:failed in unknown state
SSL_accept error from 553182-561.pph-server.de[137.74.140.78]: 0
warning: TLS library problem: error:14094418:SSL routines:SSL3_READ_BYTES:tlsv1 alert unknown ca:s3_pkt.c:1300:SSL alert number 48:
lost connection after STARTTLS from 553182-561.pph-server.de[137.74.140.78]
disconnect from 553182-561.pph-server.de[137.74.140.78]
problem remains after deleting certificate and related files, recreating
mail_send.php?err=ERRORMESSAGE&time=00-00&user= UNKNOWN:
require_once 'swiftmailer/lib/swift_required.php';
$error = $_GET['err'];
$time = $_GET['time'];
$user = $_GET['user'];
// Create the mail transport configuration
$transport = Swift_SmtpTransport::newInstance('acegames.de', 587, 'tls');
$transport->setUsername("@acegames.de");
$transport->setPassword("
$mailer = Swift_Mailer::newInstance($transport);
$message = Swift_Message::newInstance('Teamspeak Error Report');
$message->setFrom(array('admin@acegames.de' => 'Admin'));
$message->setTo(array('report@acegames.de' => 'ts3 report'));
$message->setBody(
Reported Error: ' . $error . '
Time: ' . $time . '
User: ' . $user . '
'text/html'
// Send the email
$mailer->send($message);
In my Webbrowser's (Chrome) console i get this:
GET https://ts.acegames.de/mail_send.php?err=undefined&time=undefined&user=undefined 500 (Internal Server Error)
it's not interesting thet undefined means that there is no value. The fact that it's outputting a 500-Internal-Server-Error is interesting by i dont get where the problem is.
btw. i could not connect to my webserver either (it took about a day. then everything looked fine again)
because of the same cert error as in the syslog.
But no 500 error.
Seems like the file caused the 500-error because of the certificate error.
This looks like a misconfiguration in your mail server. This isn't an apache error ( the cert is correct there), rather a mail error.
When I test I get;
Unable to open a socket to 137.74.140.78:587. Fatal error: Can't connect to "137.74.140.78:587"
Is there a firewall on your server blocking access to port 587 ? and is postfix running on your server ? any errors in the log for the mail server ?
/var/log/mail.log:
Dec 19 20:41:12 553182-561 postfix/smtpd[32750]: SSL3 alert read:fatal:unknown CA
Dec 19 20:41:12 553182-561 postfix/smtpd[32750]: SSL_accept:failed in unknown state
Dec 19 20:41:12 553182-561 postfix/smtpd[32750]: SSL_accept error from 553182-561.pph-server.de[137.74.140.78]: 0
Dec 19 20:41:12 553182-561 postfix/smtpd[32750]: warning: TLS library problem: error:14094418:SSL routines:SSL3_READ_BYTES:tlsv1 alert unknown ca:s3_pkt.c:1300:SSL alert number 48:
Dec 19 20:41:12 553182-561 postfix/smtpd[32750]: lost connection after STARTTLS from 553182-561.pphserver.de[137.74.140.78]
Dec 19 20:41:12 553182-561 postfix/smtpd[32750]: disconnect from 553182-561.pph-server.de[137.74.140.78]
ive just asked my hoster if there is any firewall blocking the port. waiting for an answer...zb
ive just realised that im not using STARTTLS so port is 465 but now i get ERR_CONNECTION_REFUSED on my whole apache2 server (acegames.de and its subdomains)
apache crashed. it had already crashed yesterday at 9:39 PM. but i was unable to find the error messages yesterday. so apache crashed because it could not find the certificate defined in the vhost files.researching…
i cannot find any error, relating to the 500-INTERNAL_SERVER_ERROR…
btw apache is now running with perfectly fine cert settings.
OK, now you have fixed those things, I can also connect correctly to port 587.
Are you still getting the 500 error ?
yes… it is still a 500-INTERNAL_SERVER_ERROR if, open up the site:
https://ts.acegames.de/mail_send.php?err=error&time=00-00&user=username
What is there in your apache log ? (and error log)
/var/log/apache2/error.log:
[Tue Dec 20 21:04:51.944729 2016] [:error] [pid 9649] [client 17.142.142.189:45438] PHP Fatal error: Uncaught exception 'Swift_TransportException' with message 'Connection to tcp://acegames.de:465 Timed Out' in /var/www/html/ts/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php:404\nStack trace:\n#0 /var/www/html/ts/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php(289): Swift_Transport_AbstractSmtpTransport->_getFullResponse(0)\n#1 /var/www/html/ts/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php(117): Swift_Transport_AbstractSmtpTransport->_readGreeting()\n#2 /var/www/html/ts/swiftmailer/lib/classes/Swift/Mailer.php(79): Swift_Transport_AbstractSmtpTransport->start()\n#3 /var/www/html/ts/mail_send.php(36): Swift_Mailer->send(Object(Swift_Message))\n#4 {main}\n thrown in /var/www/html/ts/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php on line 404
just found out about this error
others following...
Dec 20 07:06:28 553182-561 dovecot: imap-login: Login: user=admin@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5490, TLS, session=<46kk1hBEPgC8riHH>
Dec 20 07:06:31 553182-561 dovecot: imap-login: Login: user=support@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5495, TLS, session=
Dec 20 07:06:31 553182-561 dovecot: imap-login: Login: user=hoster@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5496, TLS, session=
Dec 20 07:06:31 553182-561 dovecot: imap-login: Login: user=wiki@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5497, TLS, session=
Dec 20 07:06:32 553182-561 dovecot: imap-login: Login: user=cloud@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5498, TLS, session=
Dec 20 07:06:34 553182-561 dovecot: imap(hoster@acegames.de): Connection closed in=1042 out=3714
Dec 20 07:06:34 553182-561 dovecot: imap(cloud@acegames.de): Connection closed in=1042 out=3708
Dec 20 07:06:35 553182-561 dovecot: imap(wiki@acegames.de): Connection closed in=1050 out=8443
Dec 20 07:06:35 553182-561 dovecot: imap(support@acegames.de): Connection closed in=1091 out=8574
Dec 20 07:06:41 553182-561 dovecot: imap-login: Login: user=ts3status@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5500, TLS, session=
Dec 20 07:06:42 553182-561 dovecot: imap(ts3status@acegames.de): Connection closed in=624 out=2141
Dec 20 07:06:44 553182-561 dovecot: imap-login: Login: user=admin@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5502, TLS, session=
Dec 20 07:06:45 553182-561 dovecot: imap-login: Login: user=info@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5510, TLS, session=
Dec 20 07:06:45 553182-561 dovecot: imap-login: Login: user=report@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5511, TLS, session=
Dec 20 07:06:45 553182-561 dovecot: imap-login: Login: user=superadmin@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5512, TLS, session=<82A61xBEwAC8riHH>
Dec 20 07:06:45 553182-561 dovecot: imap-login: Login: user=luke@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5513, TLS, session=<2Zs61xBEXQC8riHH>
Dec 20 07:06:45 553182-561 dovecot: imap-login: Login: user=noreply@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5514, TLS, session=
Dec 20 07:06:45 553182-561 dovecot: imap-login: Login: user=accounts@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5515, TLS, session=<+tA61xBEmwC8riHH>
Dec 20 07:06:45 553182-561 dovecot: imap-login: Login: user=trash@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, mpid=5516, TLS, session=
Dec 20 07:06:47 553182-561 dovecot: imap(luke@acegames.de): Connection closed in=624 out=2136
Dec 20 07:06:47 553182-561 dovecot: imap(accounts@acegames.de): Connection closed in=1042 out=3707
Dec 20 07:06:48 553182-561 dovecot: imap(report@acegames.de): Connection closed in=1148 out=6982
Dec 20 07:06:48 553182-561 dovecot: imap(noreply@acegames.de): Connection closed in=1467 out=5146
Dec 20 07:06:49 553182-561 dovecot: imap(trash@acegames.de): Connection closed in=1871 out=7265
Dec 20 07:06:50 553182-561 dovecot: imap(info@acegames.de): Connection closed in=1879 out=28046
Dec 20 07:06:50 553182-561 dovecot: imap(superadmin@acegames.de): Connection closed in=1934 out=19705
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=admin@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=superadmin@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=support@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=<84GP1BBEqAC8riHH>
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=report@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=trash@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=hoster@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=<45GQ1BBExwC8riHH>
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 59 secs): user=cloud@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 59 secs): user=wiki@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:06:59 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 59 secs): user=info@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=<80uS1BBEqwC8riHH>
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=wiki@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=info@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=cloud@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 60 secs): user=hoster@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=<6Re62xBEmwC8riHH>
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 61 secs): user=trash@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 61 secs): user=report@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 61 secs): user=superadmin@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=<15e22xBESQC8riHH>
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 61 secs): user=support@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=
Dec 20 07:09:00 553182-561 dovecot: imap-login: Disconnected (auth failed, 1 attempts in 61 secs): user=admin@acegames.de, method=PLAIN, rip=188.174.33.199, lip=137.74.140.78, TLS: Disconnected, session=<1Ray2xBEGwC8riHH>
and i do get this sh*t spammed into my logs:
(so currently my syslog of only today since 5 AM is over 7 Megabites of data.)
Dec 20 05:55:37 553182-561 postfix/smtpd[5072]: connect from unknown[80.82.77.83]
Dec 20 05:55:42 553182-561 postfix/smtpd[5072]: warning: unknown[80.82.77.83]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Dec 20 05:55:42 553182-561 postfix/smtpd[5072]: disconnect from unknown[80.82.77.83]
Dec 20 05:58:39 553182-561 postfix/smtpd[5099]: initializing the server-side TLS engine
Dec 20 05:58:39 553182-561 postfix/smtpd[5099]: warning: hostname vps863.hidehost.net does not resolve to address 91.200.12.140: Name or service not known
Dec 20 05:58:39 553182-561 postfix/smtpd[5099]: connect from unknown[91.200.12.140]
Dec 20 05:58:44 553182-561 postfix/smtpd[5099]: warning: unknown[91.200.12.140]: SASL LOGIN authentication failed: UGFzc3dvcmQ6
Dec 20 05:58:44 553182-561 postfix/smtpd[5099]: lost connection after AUTH from unknown[91.200.12.140]
Dec 20 05:58:44 553182-561 postfix/smtpd[5099]: disconnect from unknown[91.200.12.140]
hostname rno-dsl1a-100.gbis.net does not resolve to address 216.82.142.100
i’ve just retryed to find something in the logs but i cannot find anything.
200 lines sht
1-5 lines log
200 lines sh
t
…unable to find anything till i can open the log file and read without deleting hundreds of lines so that i can understand the log entrys.
mail.log (19-21 December)
https://download.acegames.de/mail.log
syslog (21 December)
https://download.acegames.de/syslog.log
