MailInABox certificate issue
My domain is: gideon-it.co.uk
I ran this command: MailInABox runs the command - so I've no idea!
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log Requesting a certificate for gideon-it.co.uk and 4 more domains An unexpected error occurred: Certification Authority Authorization (CAA) records forbid the CA from issuing a certificate :: Error finalizing order :: Rechecking CAA for "mta-sts.gideon-it.co.uk" and 3 more identifiers failed. Refer to sub-problems for more information Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
My web server is (include version):nginx
The operating system my web server runs on is (include version):Ubuntu 22.04.4 LTS
My hosting provider, if applicable, is: self-hosted on a VM
I can login to a root shell on my machine (yes or no, or I don't know): Yes (I think)
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):MailInABox
EDIT
Just tried again and got the following...
Saving debug log to /var/log/letsencrypt/letsencrypt.log Requesting a certificate for gideon-it.co.uk and 4 more domains An unexpected error occurred: Certification Authority Authorization (CAA) records forbid the CA from issuing a certificate :: Error finalizing order :: While processing CAA for www.gideon-it.co.uk: DNS problem: server failure at resolver looking up CAA for gideon-it.co.uk Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
As far as I can tell the DNS is all OK. But as we know "It's always DNS"!!!
neither unboundtest or letsdebug saw that CAA error: hmm
Retrying the certificate provisioning I now get a different error…
Saving debug log to /var/log/letsencrypt/letsencrypt.log Requesting a certificate for gideon-it.co.uk and 4 more domains An unexpected error occurred: Certification Authority Authorization (CAA) records forbid the CA from issuing a certificate :: Error finalizing order :: Rechecking CAA for "gideon-it.co.uk" and 4 more identifiers failed. Refer to sub-problems for more information Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
Any ideas what the problem could be?
Likely something in your DNS zone.
Please show the zone file [omitting any secret stuff (if any)].
gideon-it.co.uk nameserver = ns1.box.gideon-it.com
gideon-it.co.uk nameserver = ns2.box.gideon-it.com
ns1.box.gideon-it.com   internet address = 81.174.152.174
ns2.box.gideon-it.com   internet address = 81.174.152.174
$ORIGIN gideon-it.co.uk.
$TTL 86400          ; default time to live
@ IN SOA ns1.box.gideon-it.com. hostmaster.box.gideon-it.com. (
           2024030100     ; serial number
           7200     ; Refresh (secondary nameserver update interval)
           3600     ; Retry (when refresh fails, how often to try again, should be lower than the refresh)
           1209600  ; Expire (when refresh fails, how long secondary nameserver will keep records around anyway)
           86400    ; Negative TTL (how long negative responses are cached)
	IN	NS	ns1.box.gideon-it.com.
	IN	NS	ns2.box.gideon-it.com.
	IN	A	81.174.152.174
	IN	MX	10 box.gideon-it.com.
	IN	TXT	"v=spf1 mx -all"
_dmarc	IN	TXT	"v=DMARC1; p=quarantine;"
_caldavs._tcp	IN	SRV	0 0 443 box.gideon-it.com.
_carddavs._tcp	IN	SRV	0 0 443 box.gideon-it.com.
autoconfig	IN	A	81.174.152.174
autoconfig	IN	TXT	"v=spf1 -all"
autoconfig	IN	MX	0 .
_dmarc.autoconfig	IN	TXT	"v=DMARC1; p=reject;"
autodiscover	IN	A	81.174.152.174
autodiscover	IN	TXT	"v=spf1 -all"
autodiscover	IN	MX	0 .
_dmarc.autodiscover	IN	TXT	"v=DMARC1; p=reject;"
mta-sts	IN	A	81.174.152.174
mta-sts	IN	TXT	"v=spf1 -all"
mta-sts	IN	MX	0 .
_dmarc.mta-sts	IN	TXT	"v=DMARC1; p=reject;"
www	IN	A	81.174.152.174
www	IN	TXT	"v=spf1 -all"
www	IN	MX	0 .
_dmarc.www	IN	TXT	"v=DMARC1; p=reject;"
Tests of a single CAA query work fine from various tools (unboundtest, dnsviz, ...). And, those show you don't have a CAA record which is fine.
The Let's Encrypt server will make many queries from various world-wide server farms. Do you have some sort of DDoS protection that might block a burst of queries like that?
Are you able to view your DNS server logs for any clues?
No idea how to look at DNS logs. Rather new to MailInABox and to Linux without a GUI. Spent a lifetime supporting Windows I'm afraid!
Unbelievably it's just worked!
It must have been a DNS propogation issue.
Let's Encrypt queries the authoritive DNS servers directly. It is not affected by TTL propogation.
Oh. Well that really is a mystery then!
