UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 36: ordinal not in range(128)
ajt-co.com
/root/letsencrypt/letsencrypt-auto --text certonly --renew-by-default --webroot --webroot-path /home/teedaco/public_html/ajtdashco.​com/ -d ajt-co.com -d www.ajt-co.com
2016-06-28 12:29:44,133:ERROR:certbot.error_handler:Encountered exception during recovery
2016-06-28 12:29:44,133:ERROR:certbot.error_handler:‘ascii’ codec can’t decode byte 0xe2 in position 36: ordinal not in range(128)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/error_handler.py”, line 74, in call_registered
self.funcs-1
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/auth_handler.py”, line 266, in _cleanup_challenges
self.auth.cleanup(achalls)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/plugins/webroot.py”, line 222, in cleanup
validation_path = self._get_validation_path(root_path, achall)
File “/root/.local/share/letsencrypt/lib/python2.7/site-packages/certbot/plugins/webroot.py”, line 196, in _get_validation_path
return os.path.join(root_path, achall.chall.encode(“token”))
File “/root/.local/share/letsencrypt/lib64/python2.7/posixpath.py”, line 73, in join
path += ‘/’ + b
UnicodeDecodeError: ‘ascii’ codec can’t decode byte 0xe2 in position 36: ordinal not in range(128)
An unexpected error occurred:
CloudLinux Server release 6.8
Server version: Apache/2.2.31 (Unix)
cPanel
Huh, that is pretty odd! Do you have (or are you trying to use) any internationalized domain names (domains that contain non-ASCII characters, such as an accented character (åáäàą, etc.) or non-Latin character (like Ж, ξ, ל, or ツ)?
Is it possible that such a character was ever included in any part of your account name, e-mail address, webroot path, or some other part of your system configuration?
Its extremely odd indeed.
I’ve generated plenty of SSL’s on this server for other domains, it seems to only be this domain that is having issues. There are no special characters outside a dash in the domain name:
There was a dash in the path but I renamed the folder to remove the dash and still no go.
There’s a zero-width whitespace character (U+200B) between . and com in /home/teedaco/public_html/ajtdashco.​com/.
Yay unicode! :smile:
Neat tool to find issues like that: https://r12a.github.io/uniview/
Wow man awesome find, it was actually like that in Apache conf! I just retyped it out by hand, no copy pasting and check it:
drwxr-xr-x 2 teedaco teedaco 4.0K Jun 28 21:12 ajt-co.com/
drwxr-xr-x 5 teedaco teedaco 4.0K Jun 28 21:06 ajt-co.​com/
Never seen that before! Thanks again!
