oven.greensideproductions.com.au
sudo service caddy start
Apr 4 10:32:04 oven-1 systemd-logind: New session 8 of user mark_p_edwards.
Apr 4 10:34:19 oven-1 systemd: Starting Caddy HTTP/2 web serverā¦
Apr 4 10:34:19 oven-1 caddy: Caddyfile is valid
Apr 4 10:34:19 oven-1 systemd: Started Caddy HTTP/2 web server.
Apr 4 10:34:20 oven-1 caddy: Activating privacy features⦠2020/04/04 10:34:20 [INFO] [oven.greensideproductions.com.au] acme: Obtaining bundled SAN certificate
Apr 4 10:34:22 oven-1 caddy: 2020/04/04 10:34:22 [INFO] [oven.greensideproductions.com.au] acme: Obtaining bundled SAN certificate
Apr 4 10:34:23 oven-1 caddy: 2020/04/04 10:34:23 [INFO] [oven.greensideproductions.com.au] acme: Obtaining bundled SAN certificate
Apr 4 10:34:24 oven-1 caddy: 2020/04/04 10:34:24 [INFO] [oven.greensideproductions.com.au] acme: Obtaining bundled SAN certificate
Apr 4 10:34:26 oven-1 caddy: 2020/04/04 10:34:26 [INFO] [oven.greensideproductions.com.au] acme: Obtaining bundled SAN certificate
Apr 4 10:34:27 oven-1 caddy: 2020/04/04 10:34:27 [INFO] [oven.greensideproductions.com.au] acme: Obtaining bundled SAN certificate
Apr 4 10:34:29 oven-1 caddy: 2020/04/04 10:34:29 failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :: urn:ietf:params:acme:error:rateLimited :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/, url:
Apr 4 10:34:29 oven-1 systemd: caddy.service: main process exited, code=exited, status=1/FAILURE
Apr 4 10:34:29 oven-1 systemd: Unit caddy.service entered failed state.
Apr 4 10:34:29 oven-1 systemd: caddy.service failed.
caddy
Centos 7
me
I can login to a root shell on my machine (yes or no, or I donāt know):
Iām using a control panel to manage my site (no, or provide the name and version of the control panel):
nope.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youāre using Certbot):
This is my first time using caddy - config seems fine, ip is static, DNS set-up.
