Unable to get certificate - connection reset by peer
im out of ideas
i get this error message when i try to install certificate for my nginx server.
tls-sni-01 challenge for krbserver.me
tls-sni-01 challenge for www.krbserver.me
Failed authorization procedure. www.krbserver.me (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection reset by peer, krbserver.me (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Connection reset by peer
   Domain: www.krbserver.me
   Type:   connection
   Detail: Connection reset by peer
   Domain: krbserver.me
   Type:   connection
I have checked my dns as it says, and everything is good - i have 2 a records, one for www.hostname and one for hostname - and everything is good. i can access the sites via both addresses, but i cant get this certbot to work :confused:
My domain is: krbserver.me
i ran this command: sudo certbot --nginx
output shown.
webserver is nginx 1.10.3
Hope someone can help!
You need to differentiate protocols from addresses
a google search of tls-sni + let’s encrypt might have give you some hints
Fill out the questions and I will help you out further
Andrei
i have edited in the answers. i will take a look at what you write here :slight_smile:
If you have more help for me, please go ahead, its very much appreciated :smile:
hmmmm
are you sure you are running NGINX?
Or are you proxying Tomcat via NGINX (once again useful detail to share) :smiley:
Andrei
Ok it looks like NGINX is listening on 443 but is not completing handshakes
this is most likely because it hasn’t been setup with a SSL cert and key
you can possibly set one up using the snake oil certs
But check they exist on your system first and don’t forget to restart NGINX
As you have a working port 80 i suggest you use the webroot authenticator and nginx installer
The process should have set it up and found the right directives and created a self signed certificate for you
Andrei
right, sorry, yes, i am reverse proxying to tomcat. shouldve said that.
so, how do i use the webroot authenticator? i am only running webapps on the server, no static html in any of the dirs.
and the nginx installer? if you mean certbot --nginx, then that is what gave me these errors
In this case normally users need to create an explicit mapping so that /.well-known/acme-challenge is served as static files from some directory path.
The TLS-SNI-01 method used by --nginx, as @ahaw021 mentioned, can't work from behind a reverse proxy. The HTTP-01 method used by --webroot can work but you need to be able to make externally-visible changes to the site to prove that you control it—and unless you want to reprogram one of the web apps to add some kind of API to update the content, the easiest thing would be to create a mapping so that /.well-known/acme-challenge on the site gets served from the static files in some directory.
Because --webroot tries to create /.well-known/acme-challenge inside the location that you give it, in this case you would probably also want to run
mkdir .well-known
ln -s .well-known/acme-challenge .
inside of that directory, because otherwise the webroot plugin will try to place the verification files in what amounts to /.well-known/acme-challenge/.well-known/acme-challenge instead of just /.well-known/acme-challenge.
Thank you! I finally got it to work. I swapped the domain over to a
similar, and remade my server from a backup point :slight_smile: but I did get it to
work behind a reverse proxy - check https://Breindal.me for verification :slight_smile:
