" Unable to find a virtual host listening on port 80" - system not using virtual hosts
My domain is: sitetruth.com
I ran this command: /certbot-auto renew
[root@s3 letsencrypt]# ./certbot-auto renew
Processing /etc/letsencrypt/renewal/sitetruth.com.conf
http-01 challenge for www.sitetruth.com
http-01 challenge for sitetruth.com
http-01 challenge for s3.sitetruth.com
Attempting to renew cert (sitetruth.com) from /etc/letsencrypt/renewal/sitetruth.com.conf produced an unexpected error: Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80… Skipping.
/etc/letsencrypt/live/sitetruth.com/fullchain.pem (failure)
My web server is (include version): Apache 2.4.6 (CentOS)
The operating system my web server runs on is (include version): CentOS 7.1.1503
My hosting provider, if applicable, is: Codero.
I can login to a root shell on my machine (yes or no, or I don’t know): Yes.
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes, but I’m not using it for certbot
It just auto-updated to 0.34.2, and now it won’t renew
This machine hosts only one domain, so it doesn’t use virtual hosts.
This is just a renewal. It used to work. I haven’t changed anything on this server in over a year.
Hi @John-Nagle
there is a Letsencrypt certificate ( https://check-your-website.server-daten.de/?q=sitetruth.com ):
CN=sitetruth.com
	10.05.2018
	08.08.2018
277 days expired
s3.sitetruth.com, sitetruth.com, www.sitetruth.com - 3 entries
But it's from last year, so you don't really use it.
You have three old and expired certificates. With a lot of time between these certificates.
CRT-Id Issuer not before not after Domain names LE-Duplicate next LE
454298225 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2018-05-09 21:32:43 2018-08-07 21:32:43 s3.sitetruth.com, sitetruth.com, www.sitetruth.com
3 entries
312076423 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2018-01-24 02:02:42 2018-04-24 01:02:42 s3.sitetruth.com, sitetruth.com, www.sitetruth.com
3 entries
195972135 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2017-08-22 01:14:00 2017-11-20 02:14:00 s3.sitetruth.com, sitetruth.com, www.sitetruth.com
3 entries
What's your control panel? Perhaps it's impossible to use that control panel and to create own virtual hosts.
This isn't a renew. There is no working Letsencrypt configuration. 2017 you may have used tls-sni-01 validation, that's not longer supported.
That's a simple thing. Check your installation, there are samples how to create new config files.
I have a real host on port 80. One server, one host. Why do I need a virtual one? Everything except LetsEncrypt works fine with that configuration.
Try “http://www.sitetruth.com:80”. Works fine.
Isn’t it a bug that LetsEncrypt won’t work right any more with a basic Apache configuration? Especially since it used to work?
