Unable to determine base domain for _acme-challenge.ess.eu using names
My domain is: ess.eu
I ran this command: certbot --text --agree-tos --non-interactive certonly --rsa-key-size 4096 -a dns-rfc2136 --cert-name 'sftp.ess.eu' -d 'sftp.ess.eu' --dns-rfc2136-credentials /etc/letsencrypt/dns-rfc2136.ini --dns-rfc2136-propagation-seconds 10 --keep-until-expiring
dns-01 challenge for sftp.ess.eu
Encountered exception during recovery: PluginError: Unable to determine base domain for _acme-challenge.sftp.ess.eu using names: ['_acme-challenge.sftp.ess.eu', 'sftp.ess.eu', 'ess.eu', 'eu'].
This command works:
certbot --text --agree-tos --non-interactive certonly --rsa-key-size 4096 -a dns-rfc2136 --cert-name 'wildcard' -d '*.ess.eu' --dns-rfc2136-credentials /etc/letsencrypt/dns-rfc2136.ini --dns-rfc2136-propagation-seconds 10 --keep-until-expiring
My web server is (include version): haproxy 1.8
The operating system my web server runs on is (include version): CentOS 7
no
certbot 1.11.0
I created a new name server and migrated to it recently. After that, dns-01 failed.
The dns-rfc2136.ini config is:
dns_rfc2136_server=new_ns.domain
dns_rfc2136_port=53
dns_rfc2136_name=key_name
dns_rfc2136_secret=secret
dns_rfc2136_algorithm=HMAC-SHA256
Is there anything wrong with the configuration or my name server?
Please see e.g. sftp.ess.eu | DNSViz Looks like quite the mess for the sftp subdomain.
Also, as far as I know, Certbot and the Certbot RFC 2136 plugin doesn't play nice with CNAMEs. There should be an issue about that on the Certbit Github repo.
Edit: Found the issue: Allow updating domain pointed to by CNAME in DNS plugins · Issue #6566 · certbot/certbot · GitHub
I don't think the CNAME should matter in this case. There is no CNAME on the _acme-challenge label.
Basically, the error says that the nameserver you're sending the update to (new_ns.domain) doesn't think that it's authoritative for ess.eu. If you query your nameserver for the SOA record of that domain, it should come with a response. In your case, it's probably returning REFUSED.
A good response looks like:
$ dig +norecurse +tcp +noall +answer @ns1.esss.se ess.eu soa
ess.eu.                 10800   IN      SOA     ess.eu. registry.esss.se. 2023051712 3600 1800 604800 10800
