Unable to create single cert first try for me
My domain is:plspro.com
[root@testvm certs]# certbot certonly --webroot -w /var/www/html -d testvm.plspro.com.com --dry-run
Simulating a certificate request for testvm.plspro.com.com
Domain: testvm.plspro.com.com
Detail: Invalid response from http://testvm.plspro.com.com/.well-known/acme-challenge/B9F10ZjDNi5VA3d_sADcKb_Oamv4XcVkkqM1N7kfJVE [45.11.57.36]: "\r\n404 Not Found\r\n\r\n
404 Not Found
\r\n
nginx/1.18.0 (Ub"
My web server is (include version):slight_smile:
[root@testvm certs]# apachectl -v
Server version: Apache/2.4.6 (Red Hat Enterprise Linux)
Server built: Oct 29 2021 12:32:51
The operating system my web server runs on is (include version):rhel 7
My hosting provider, if applicable, is: n/a
[root@testvm certs]# certbot --version
certbot 1.21.0
Please ignore the com.com
[root@testvm certs]# certbot certonly --webroot -w /var/www/html -d testvm.plspro.com --dry-run
Detail: Invalid response from Business profile for plspro.com provided by Network Solutions [205.178.189.129]: "\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-"
I am assuming there is something in the hint -
Not sure what that means.
Hi Chris (@ccheltenham), Welcome to the LE community.
Network Solutions sells their own certificates - as shown by your apex domain of plspro.com. They do not give you root access, but will install a free LE cert for you for a charge (US$59.99?). With this hosting provider, whether you buy one of their certs or obtain a free LE cert, they are the one who will have to install it - for a charge. :unamused:
Here's two links, an older one and a fairly recent one discussing Network Solutions and LE certs.
You may want to switch to another hosting provider that allows you to install your own (LE) certificate. There's a long list of hosting providers at this link who support Lets Encrypt free certs.
I see ok. I can't do that.
Ok I'll let you know.
Thanks
Address: 205.178.189.129
You need a working HTTP site before you can secure it (via HTTP authentication).
An "under construction" page does NOT count as a working HTTP site.
