Unable to Create Certificates for 2 Sites on Same IP
hi,
I am an experienced developer but have run into an issue setting up lets encrypt on an Ubuntu bionic virtual private server.
My domains are:
gordonbanderson.com
arbroathunited.cc
Now I had this working with just gordonbanderson.com. The command I ran was
certbot certonly -v --staging --no-eff-email --webroot --preferred-challenges http --email "gordon.b.anderson+gba@gmail.com" --agree-tos -d gordonbanderson.com -d www.gordonbanderson.com -w /var/www/gba/public/
When I added arbroathunited.cc as a domain to the same IP address the above command fails, when I try to create a certificate for gordonbanderson.com it tries to authenticate against the other domain associated with the server, arbroathunited.cc:
Output from the above command after adding the second domain, https://pastebin.com/6ANANPDz
nginx 1.17.4
The virtual hosts are responding correct, I added the same filename to both servers with different text, and the responded as expected.
Alpine Linux 3.10 (note I am using docker with multiple containers). Certbot is running Debian stretch
Digital Ocean
NO, using SSH
0.28.0, certbot
The attempt to authorize gordonbanderson.com against the webroot of arbroathunited.cc, which is failing, is where I am confused.
Any pointers appreciated
Regards
Gordon
Your server is generating a redirect from the gordonbanderson.com to arbroathunited.cc:
$ curl -X GET -I gordonbanderson.com/.well-known/acme-challenge/test
Server: nginx
Date: Sat, 19 Oct 2019 23:32:34 GMT
Content-Type: text/html
Content-Length: 162
Location: https://arbroathunited.cc/.well-known/acme-challenge/test
Let's Encrypt is just following the redirect, which produces the appearance of it trying to authenticate against the wrong domain.
hi,
Thanks for the heads up, I had not though to look at the nginx config. The issue was was that the server name gordodnbanderson.com was missing from the redirect (I previously only had the www version):
listen 80;
server_name gordonbanderson.com www.gordonbanderson.com;
rewrite ^ https://gordonbanderson.com$uri permanent;
There was a second issue in that certbot uses IPV6 and IPV4 fallback appears to fail. Enabling IPV6 on the Digital Ocean interface, tweaking the network configuration via SSH, and adding IPV6 listening to the nginx config resolved the problem.
