I’m not really sure where to start or what to do. I hope I’ve provided enough information. Everything was running great until the certificate expired and when I tried to renew, it wouldn’t.
Processing /etc/letsencrypt/renewal/gitlab.omniteklabs.com.conf
http-01 challenge for gitlab.omniteklabs.com
http-01 challenge for project.omniteklabs.com
Attempting to renew cert (gitlab.omniteklabs.com) from /etc/letsencrypt/renewal/gitlab.omniteklabs.com.conf produced an unexpected error: Failed authorization procedure. gitlab.omniteklabs.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://gitlab.omniteklabs.com/.well-known/acme-challenge/qUO8nY4rrNtOZJh0eiF8lSLUMrvVecxBBvGPHTp9acs: Connection refused, project.omniteklabs.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://project.omniteklabs.com/.well-known/acme-challenge/uztDz1GH0zDUq2wfjdvihjPzpdH2t2uAjpqXESCy9S8: Connection refused. Skipping.
/etc/letsencrypt/live/gitlab.omniteklabs.com/fullchain.pem (failure)
Domain: gitlab.omniteklabs.com
Type: connection
Detail: Fetching
Connection refused
Domain: project.omniteklabs.com
Type: connection
Detail: Fetching
Connection refused
My web server is (include version): Server version: Apache/2.4.18 (Ubuntu), Server built: 2017-09-18T15:09:02
The operating system my web server runs on is (include version): Linux gitlab 4.13.0-37-generic #42~16.04.1-Ubuntu SMP Wed Mar 7 16:03:28 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): if the gitlab config file counts.
You should review your firewall and/or port forwarding conf because I’m also getting a connection refused error trying to reach your sites.
$ curl -IkL http://gitlab.omniteklabs.com
curl: (7) Failed to connect to gitlab.omniteklabs.com port 80: Connection refused
$ curl -IkL http://project.omniteklabs.com
curl: (7) Failed to connect to project.omniteklabs.com port 80: Connection refused
Okay, so I looked into and apparently Apache was not starting up like it should. It had something to do with permissions in the sites-enabled folder. Both sites come up now.
So now when I do sudo certbot renew --dry-run it comes back with this
omnitek@gitlab:~$ sudo certbot renew --dry-run
Attempting to renew cert (gitlab.omniteklabs.com) from /etc/letsencrypt/renewal/gitlab.omniteklabs.com.conf produced an unexpected error: Failed authorization procedure. gitlab.omniteklabs.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://gitlab.omniteklabs.com/.well-known/acme-challenge/GEx_VbMqa9zrVH7z3qSF0WHaZkbliFY7HbXC2yUkYtg: "<!DOCTYPE html>
<html class="devise-layout-html">
<head prefix="og: http://ogp.me/ns#">
<meta charset="utf-8">
<meta content="IE". Skipping.
Detail: Invalid response from
"<!DOCTYPE html>
<meta content="IE"
@cadtek91, check whether the webroot in /etc/letsencrypt/renewal/gitlab.omniteklabs.com.conf is the same as in your web server conf. If it is the same, put a test file in /path/to/your/webroot/.well-known/acme-challenge/ and try to reach it from a public network.
Example:
echo "this is a test" > /path/to/your/webroot/.well-known/acme-challenge/test
It was not the same, however I updated the letsencrypt conf to the same DocuemtRoot from the virtualhost conf
It’s now
omnitek@gitlab:~$ cat /etc/letsencrypt/renewal/gitlab.omniteklabs.com.conf
cert = /etc/letsencrypt/live/gitlab.omniteklabs.com/cert.pem
privkey = /etc/letsencrypt/live/gitlab.omniteklabs.com/privkey.pem
chain = /etc/letsencrypt/live/gitlab.omniteklabs.com/chain.pem
fullchain = /etc/letsencrypt/live/gitlab.omniteklabs.com/fullchain.pem
version = 0.17.0
archive_dir = /etc/letsencrypt/archive/gitlab.omniteklabs.com
# Options and defaults used in the renewal process
[renewalparams]
installer = None
authenticator = webroot
account = e968d255a3d5e159a99f8795ef23cd32
[[webroot_map]]
gitlab.omniteklabs.com = /opt/gitlab/embedded/service/gitlab-rails/public
project.omniteklabs.com = /opt/openproject/public
I did a dry run after I changed that, and apparently that worked… figures it was something really small like that.
new certificate deployed without reload, fullchain is
/etc/letsencrypt/live/gitlab.omniteklabs.com/fullchain.pem (success)
