manual-auth-hook is running twice because I have -d "example.com" -d "*.example.com" (just an example) but both times it runs $CERTBOT_IDENTIFIER equals example.com so the second run does the same thing as the first. Is it necessary to run twice?
Do I miss something in the process? In the manual-auth-hook I update the _acme-challenge TXT to be $CERTBOT_VALIDATION using the API from the DNS host. The script runs both times and updates the TXT record each time. I can see it worked using dig and using the DNS host API. But certificates don't get created.
Challenge failed for domain example.com
dns-01 challenge for Identifier(typ=IdentifierType(dns), value='example.com')
Identifier: example.com
Detail: No TXT record found at _acme-challenge.example.com
Hint: The Certificate Authority failed to verify the DNS TXT records created by the --manual-auth-hook. Ensure that this hook is functioning correctly and that it waits a sufficient duration of time for DNS propagation. Refer to "certbot --help manual" and the Certbot User Guide.
The hint says the hook should wait but I do wait. At the end of my script I put sleep 100 because TTL is 100 so it has enough time to propagate. Sometimes the error says there's no TXT record and sometimes it says the TXT record is wrong and it shows the earlier value.
Do I need to sleep much longer at the end of the script?
Is there an example of how to use manual certonly with wildcard DNS challenge that uses an API to update the TXT record?
Yes, once for each identifier in the cert. The example.com and *.example.com are different identifiers even though they are validated using the same name for the DNS TXT record. DNS does not allow * in the name.
Well, Let's Encrypt queries the authoritative DNS servers directly. They have to sync worldwide but LE is not affected by TTL. If TTL affects your DNS server sync process that's fine. Just wanted to be clear about TTL and LE.
There are other ACME Clients that support a wider variety of DNS provider APIs. Had you provided your actual domain name like was requested I could have given more specific advice. But, look at the lego acme client which supports a large variety of DNS provider APIs and often gets support for new features promptly.
Also, I changed the domain name in your first post to example.com assuming it was a sample.
But, the domain name you used is a valid domain owned by someone. If you actually own it I apologize. Let me know and I will revert my change. If not, please do not use other people's domain names in posts.
If it is your domain your solution is easy as its DNS provider is Cloudflare which is readily supported by Certbot's plugin. See Certbot docs link I provided in prior post.
Yes but for DNS validation does it make a difference if it's an internal host if the DNS host for it is public?
I tried dig TXT _acme-challenge.example.com and it shows both TXT values. Is there a DNS server I should use with dig TXT @$DNS_SERVER _acme-challenge.example.com?
The IP addresses do not appear to be in an anycast network and load balancers for DNS servers aren't typically used, so the challenge should be able to succeed as soon as the records appear.
