Second DNS challenge fails using custom manual_auth_hook
  • I am using a manual_auth_hook that directly pushes dns challenges onto my own dns server.
  • The first challenge is always successful. I a second challenge is issued, it fails, claiming that a wrong dns entry was found
  • in the log below
    • my manual_auth_hook script logs the requested challenges
    • the ‘wrong’ challenge logged by certbot in the very end is exactly the same than the one requested to my script
  • my TXT entries have TTL 1
  • in this attempt, my script already had a waiting of 5 secs after updating the DNS record
My domain is: *.haug.in
Processing /etc/letsencrypt/renewal/haug.in.conf
dns-01 challenge for haug.in
Running manual-auth-hook command: /etc/letsencrypt/dns-updater.sh
Output from manual-auth-hook command dns-updater.sh:
Domain
haug.in
ssh -p6554 dns@vs2.ing-haug.de ./updateacme haug.in KXlgbS-krNBvcIoFMBjgT6A5AHPR8-IwwMVwF46-6do
validation
Domain
haug.in
ssh -p6554 dns@vs2.ing-haug.de ./updateacme haug.in M_Buq1fuEZVdVe9JMn3ukU6OS0kF8oybyE5QKWmzkHI
validation
Waiting for verification…
Challenge failed for domain haug.in
Attempting to renew cert (haug.in) from /etc/letsencrypt/renewal/haug.in.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/haug.in/fullchain.pem (failure)
Running post-hook command: /etc/letsencrypt/renewal-hooks/post/restart-dovecot
Running post-hook command: /etc/letsencrypt/renewal-hooks/post/restart-nginx
Running post-hook command: /etc/letsencrypt/renewal-hooks/post/restart-postfix
    Domain: haug.in
    Detail: Incorrect TXT record
    “M_Buq1fuEZVdVe9JMn3ukU6OS0kF8oybyE5QKWmzkHI” found at
    _acme-challenge.haug.in
My web server is (include version): unused
Linux fsoc.haug.in 5.2.17-200.fc30.x86_64 #1 SMP Mon Sep 23 13:42:32 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
My hosting provider, if applicable, is: own web server, own DNS servers
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.38.0
Hi @Philadelphia
checking your domain via haug.in - Make your website better - DNS, redirects, mixed content, certificates - you have created today two certificates:
Let's Encrypt Authority X3 2020-06-06 2020-09-04 *.haug.in, haug.in - 2 entries duplicate nr. 2
Let's Encrypt Authority X3 2020-06-06 2020-09-04 *.haug.in, haug.in - 2 entries duplicate nr. 1
Let's Encrypt Authority X3 2020-03-20 2020-06-18 *.haug.in, haug.in - 2 entries
So I don't understand your question.
Use one of these, don't create the next certificate, there is a rate limit.
Yes - it worked - because there was just one challenge. It had 60 secs delay (before 5 secs)
I had a couple of dry-runs with two challenges who failed.
I thought it might be interesting for you to fix it.
The log indicates a letsencrypt failure, correct ? Or did I draw a wrong conclusion ?
I later might be able to provide wireshark logs from the DNS server and the certbot logfiles.
Right now, I obviously reached a limit - the OK comes without DNS communication
Letsencrypt validations are cached and 30 days re-used.
So if you validate one domain name, the other fails. Next step, you need only one validation.
Checking your domain that looks wrong - https://check-your-website.server-daten.de/?q=haug.in#txt
There is only one TXT entry visible.
If you want a certificate with two domain names (both via dns validation), two TXT entries with the same name, but different values are required.
That
looks that your script creates one entry, then overwrites the value with the second entry, that’s wrong.
Two entries with the same domain name _acme-challenge.haug.in, but different values should be visible after you have created these two entries and before Letsencrypt checks the result.
Yes, you are right. The script was called twice for two different certs. Obviously the renewals are executed asynchronously, running in parallel, the later not waiting for the former to finish.
The right way to handle this is then
  • add the _acme-challenge TXT record using the manual_auth_hook
  • remove the specific record from a second script hooked to the manual_clenaup_hook
Problem solved, thanx a lot
