Looks like you have a firewall blocking specific IP addresses or ranges. I can reach your domain just fine on port 80 (http) and port 443 (https). But, Let's Debug reproduces your error consistently. Both its own http test and using Let's Encrypt staging server.
I checked the common cases for a Palo Alto brand firewall but do not see that as a problem. I mention this for benefit of other volunteers. Looks like a general firewall problem.
Thanks for all your messages. my ISP is TSOHOST who got rid of automatic letsencrypt renewal for a yearly paid certificate. That is why I am using Certsage
So the fact that you suspect a firewall is blocking the requests could be an attempt by TSOHOST to close the Certsage loophole.
I get these same 200 OK or (expected) 404 Not Found if I repeat these requests rapidly after the initial 'reset by peer'.
But, if I wait 8 minutes my first request again gets 'reset by peer' followed by working responses. This is some sort of comms config issue with your hosting service.
It's possible waiting less than 8 minutes is enough to again see 'reset by peer' I just didn't test the limits. I think in prior threads just 2 or 3 minutes between was enough.
I just responded to you via email because I didn't see this thread. I'm very glad my colleagues here have been helping to diagnose the issue and I believe they're on the right track. If they're seeing the same behavior for your main website content, it's not an attempt to block CertSage. I suggest checking with TSOHOST about the general issue, but don't mention CertSage specifically since it's a general connectivity problem, not a CertSage operational problem.
Show them the sequence I showed in post #10. I could repeat the problem today with only a 2.5min wait time after success. These are just for your home page so have nothing to do with certsage.
Please provide TSOHOST the curl snippet from @MikeMcQ's post directly above. It illustrates the inconsistency with which your webserver can be reached in general.
Had a conversation with TSOHOST support which didn't go well. I pointed out the issues and provided the Curl code snippets. Support person suggested that I might want to change browser? I pointed out the connection was being reset but could not get any sense out the support person as to why this might be happening.
We tried to keep ACME (and CertSage) out of the discussion completely to keep TSOHOST from incorrectly pointing fingers at those specifically rather than addressing the general connectivity problem that's clearly present.
I reproduced this problem using a browser on Windows. So, not curl specific either. See below.
But, if they are willing to have users suffer having to reload the page they could get a cert using the DNS Challenge. Personally, I wouldn't want anyone to see the failure but we don't know how broad it is. I have reproduced using several different IP addresses but all in the USA, for example.
This is well beyond a question of getting / using certs. Still, I would be curious to learn a solution to more quickly help people. We've seen this a number of times now.
Here are example pics using Edge on Windows 10. I used a private window and reproduced this twice. Once with http:// and again (below) with https://.
