Trying renew after installation fails with 'lacks sufficient authoriation'
www.gratwifi.eu
certbot --dry-run
Processing /etc/letsencrypt/renewal/gratwifi.eu.conf
http-01 challenge for beta.gratwifi.eu
http-01 challenge for dashboard.gratwifi.eu
http-01 challenge for portal.gratwifi.eu
http-01 challenge for gratwifi.eu
http-01 challenge for www.gratwifi.eu
Waiting for verification…
Attempting to renew cert (gratwifi.eu) from /etc/letsencrypt/renewal/gratwifi.eu.conf produced an unexpected error: Failed authorization procedure. www.gratwifi.eu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.gratwifi.eu/.well-known/acme-challenge/DEZ3c4CFlNSPYBgQsKlbppaBN1kHkjN9Cg3nXdO3BE0: “”, gratwifi.eu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://gratwifi.eu/.well-known/acme-challenge/0a3TW6nD9G0YCRY-AvoLPq4LB61PKJejvfqUyLN4gjw: “”. Skipping.
/etc/letsencrypt/live/gratwifi.eu/fullchain.pem (failure)
    Domain: www.gratwifi.eu
    Detail: Invalid response from
    Domain: gratwifi.eu
    nginx version: nginx/1.12.2
    Ubuntu 14.04.5 LTS
    own server
    no
From the output of your server you have configured nginx with proxy_pass to a Ruby application, yes?
You might need to add an exclusion for /.well-known/acme-challenge to prevent the Ruby application from intercepting those requests, but I am surprised that the Certbot nginx plugin is not doing it for you:
  # No contents needed, just need to override proxy_pass
Yes, it is a proxy_pass to a ruby (and elixir) app.
Is see in the log a couple of times this:
server {rewrite ^(/.well-known/acme-challenge/.*) $1 break; # managed by Certbot
I don't know if that is what you mean.
I added the rules and now I get this:
Attempting to renew cert (gratwifi.eu) from /etc/letsencrypt/renewal/gratwifi.eu.conf produced an unexpected error: Failed authorization procedure. www.gratwifi.eu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.gratwifi.eu/.well-known/acme-challenge/ddvP8_x4z3sWpnu2ASjv5e07R2LppmY-lx72H2HDo3I: "
404 Not Found
404 Not Found
", gratwifi.eu (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://gratwifi.eu/.well-known/acme-challenge/hYE4ct-K0_cXhfpCGuCtwxGXfpRsY4TCLofQwakIDgc: " 404 Not Found
404 Not Found
". Skipping. All renewal attempts failed. The following certs could not be renewed: /etc/letsencrypt/live/gratwifi.eu/fullchain.pem (failure)
I just checked the code of the Certbot nginx plugin and it appears I have misunderstood how it works. My advice isn’t helpful, you can get rid of that location block.
The plugin works by temporarily adding something like
location = /.well-known/acme-challenge/xyxyxyxyxy {
  default_type text/plain;
  return 200 'abababababababab';
(except with the real validation values) and reloading nginx.
So the problem in your case would be that for some reason, that change isn’t being applied by/loaded by nginx.
It might help to try with --dry-run --debug and upload the full /var/log/letsencrypt/letsencrypt.log somewhere so it can be checked for issues.
can we do this somewhere private?
Sure, you can PM someone for help, however I am off to bed so it may be worth waiting to see if someone like schoen or bmw have any ideas.
Not really—I’d like to see the logs and also to check what version of Certbot it is (although it must be reasonably recent because it’s doing HTTP-01 with --nginx).
How can I PM you with the link?
I just edited your forum account so that you should now be able to send PMs.
Hi @Hermanverschooten, I tried looking at your log briefly.
One thing that seems important to double-check: Some of your hostnames have both the IPv6 address 2a03:a800:12:1::4728:9434 and the IPv4 address 77.73.99.74, while some have only the IPv4 address. While it does appear that both the IPv4 and IPv6 versions of http://gratwifi.eu/ are operating and serving the same web content, can you confirm that this server is meant to have both IP addresses and that the IPv6 address does, in fact, point directly at the machine where you ran the Certbot command?
Hi @schoen,
Yes they both point to the same machine, and I need to change it so all sites use the IPv6.
I don’t know exactly why, but I split the file that contained both www.gratwifi.eu and portal.gratwifi.eu, and now it is working.
