Trouble renewing certificate - certbot 0.40.0
Here is a run that shows what is happening. Below is the output from letsdebug and feel free to run your own as it is up full time.
/usr/bin/certbot renew --cert-name acadia.k12.la.us --dry-run
Processing /etc/letsencrypt/renewal/acadia.k12.la.us.conf
http-01 challenge for acadia.k12.la.us
http-01 challenge for www.acadia.k12.la.us
Challenge failed for domain acadia.k12.la.us
Attempting to renew cert (acadia.k12.la.us) from /etc/letsencrypt/renewal/acadia.k12.la.us.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/acadia.k12.la.us/fullchain.pem (failure)
    Domain: acadia.k12.la.us
    Type: connection
    Detail: Fetching
    http://acadia.k12.la.us/.well-known/acme-challenge/bSeDla6lzSTM56Nn9vSBwqOqTscthT0ytvzb4mnMvFY:
    Timeout after connect (your server may be slow or overloaded)
![letsencrypt2|690x55]
If I run it while the process is happening I get the following returned in the web browser. I am only allowed to attach 1 media as I am a new user.
URL:
https://acadia.k12.la.us/.well-known/acme-challenge/Sxu_YMriaKuGjML2xV6pJ0iwPbjlpJAjWNoBGsNkUoA
Result in browser: Sxu_YMriaKuGjML2xV6pJ0iwPbjlpJAjWNoBGsNkUoA.dxzKATtDb7LPjYpbLMOLltTCXYKQjPUnPrgnAvKGNbU
Hi @StealthMicro
there are some curious things.
Why
is there a timeout? Looks like your server doesn't answer. Or is this a blocking firewall, a blocking .htaccess or a bot detection?
Checking your domain via https://check-your-website.server-daten.de/?q=acadia.k12.la.us - your name server has the same ip address. Normally, that shouldn't be a problem - but dns over tcp doesn't work. Isn't it configured or is this a blocking firewall?
Checking /.well-known/acme-challenge/random-filename, there is the expected http result 404 - Not Found.
But why shows letsdebug a http status 200? ( /.well-known/acme-challenge/letsdebug-test ). I don't think there is a file with that file name.
Your test url has the correct content - filename, dot, a hash of the account key.
PS: Ok, there - https://acadia.k12.la.us/.well-known/acme-challenge/letsdebug-test - is a file with that file name, so the http result 200 is expected.
I get redirected from http to https, so both work for me. The redirect is a 302 though instead of a 301 like it should be.
There's a load balancer in play...
load-balancer: ies-lb-v2-ssl
Ok it helps to RTFM (once in a while):
curl -L http://acadia.k12.la.us/.well-known/acme-challenge/letsdebug-test
letsdebug-test
[-L will follow redirection]
> 302 Found
Status: 302 Found
Code: 302
content-length: 0
Location: https://acadia.k12.la.us/.well-known/acme-challenge/letsdebug-test
cache-control: no-cache
connection: close
> 200 OK
Status: 200 OK
Code: 200
date: Wed, 25 Nov 2020 04:00:47 GMT
server: Apache
last-modified: Tue, 24 Nov 2020 20:49:40 GMT
etag: "f-5b4e0731b1f56"
accept-ranges: bytes
content-length: 15
connection: close
:grin:
Seeing this always makes my spidey senses tingle...
But they seem to have got that working (as expected).
I think the main problem is that the HTTPS site is locked down tight (as it should be).
And may be blocking some of the challenge requests [that come from overseas].
The "fix" is not to allow them (in HTTPS); But to accept them in HTTP.
Don't redirect the challenge requests to HTTPS.
Here is a "sample" Apache code to get you started:
[which redirects only when the URL does not contain ".well-known"]
  <LocationMatch "^/(?!\.well-known)">
    #send all other requests to HTTPS
    RewriteEngine On
    RewriteCond %{HTTPS} !=on
    RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1
  </LocationMatch>
Any vhost using this code would need to specify the document root for when the URL does contain ".well-known".
Which has to jive with your:
I created a letsdebug-test file with letsdebug-test as the contents so I could see something other then a 404 file not found error.
Correct there is a haproxy load balancer in the middle.
I set it to use http instead of https and still having the same exact issue. Feel free to test it that way as well. The interesting thing is it looks fine using a web browser and or curl but for some reason letsdebug fails (as well as certbot)
As an FYI we have been using this configuration for over a year and have over 500 SSL's with Lets Encrypt. This only started happening recently. It is possible that a update to one of the various services involved has caused this. haproxy or apache even maybe.
I did remove the letsdebug-test file so now it shows the proper 404 error. But certbot still fails.
I'm seeing that InternalProblem too with Let's Debug, yet I can visit the site just fine. Did you remove the test file? I don't see it anymore.
Yes I did remove the test file so the normal 404 shows up now. certbot still fails. The strange thing is I do not see any attempts from letsencrypt in the apache log files using the certbot app.
Is your load balancer terminating SSL or are workers?
Load balancer is. But the strange thing all of this worked fine until recently. It should also be coming over http unless the certbot or letsencrypt forces https on its own?
Any idea what IP addresses the certbot would have letsencrypt come back as? Is it the same as letsdebug? If not I could look for that or those IP addresses and try to track those down in the firewall and try to follow the packets.
Here is a pastebin of the debug log. It is a lot of data so I am doing a pastebin so not to clutter up in here.
It looks like the site has a lot of "mixed content" (being served over htttp), which will cause the site to be shown as insecure (and no padlock to appear next to the address). There are also crawling errors.
That normally would not happen. So what happens
So what happens on my side. Someone comes in under http and a file is checked to see if they have an SSL and if so it forces all traffic to https. This normally is the way it works but for testing here I simply removed that domain from the file so we could test letsencrypt to eliminate a https challenge issue. Once testing is done then I will simply add that domain back in and all those mixed content issues will be resolved.
Depends upon your certbot renewal configuration. I haven't looked over the log yet. If you used an "installer" and specified to have certbot redirect to https then certbot maintains configuration changes to do that.
I believe that Let's Encrypt uses AWS instances and that the IP addresses vary. There have been several (heated) topics about this practice about various points in this community. The general rule is to always accept requests over port 80 for /.well-known/ . It is fine to redirect to https and have the exception there. Let's Encrypt also ignores invalid certificates along the way.
I use certonly and do not have apache do the redirection (via the certbot "installer"
I actually redirect to the letsencrypt apache server via /.well-known/acme-challenge
