It seems it just went live! I was able to request a shortlived cert just minutes ago, and my account was not whitelisted.
Without changing any configuration, the renew of my first shortlived certificates weirdly yielded a 90 day cert again. Why that?
I should note that I am using Traefik which afaik does not support ARI yet. So each renew is in fact a new cert/order I assume.
ARI is just involved in the "when" to renew. Not the "what" gets renewed
All cert "renews" are in fact new cert orders anyway. There may be differences in rate limits and such but it is a new order.
My guess is that Traefik lost track that you wanted to use the shortlived profile since your initial request. I don't know Traefik very well but their community might be better if no one else here offers help.
I moved your posts in that other thread to this new one. We like all problems to have their own.
The problems with your Traefik renewal were not related to the original post in that other thread
I suspect it can't be a problem of Traefik, as the "profile: shortlived" is hardcoded into my config. Traefik doesn't "keep track" of that, as the certbot client would do.
I'm fairly positive this is a problem of LetsEncrypt.
Well, you haven't given us much info to work with.
Google says you should be able to set debug mode for your Traefik log to get more detailed ACME API info. Would you provide the entire sequence that it shows for this request?
Also, had you started your own thread you would have been shown the form below. Please answer as much as you can. At this stage it is hard to know what is important or not so the more info we have the better.
One of the domains in question is: mta-sts.schildbach.de
Here is the last renewal with the tlsserver profile:
DNS Name = mta-sts.schildbach.de
Pubkey = a2a1f95734ba0f789ed2cabb3efbf3ac24065fef8ae0c3993ef6f320bb66b548
Issuer = C=US, O=Let's Encrypt, CN=E7
Not Before = 2025-11-03 13:35:24 +0000 UTC
Not After = 2026-02-01 13:35:23 +0000 UTC
Log Entry = 685977306 @ https://ct.googleapis.com/logs/us1/argon2026h1/
crt.sh = https://crt.sh/?sha256=eaf873917f9a1931a980a1566f0270dbfdce67b8423ee3a258ea21461f439f22
When the shortlived profile became available, I switched my configuration and triggered a new certificate:
Pubkey = 36c25bec5ec210065f79331c9c3ab468ae4d189fc8ddce70b071df80ff2443cf
Not Before = 2025-12-17 13:32:24 +0000 UTC
Not After = 2025-12-24 05:32:23 +0000 UTC
Log Entry = 737151240 @ https://mon.sycamore.ct.letsencrypt.org/2026h1/
crt.sh = https://crt.sh/?sha256=ace4e331c4478e01b8f677057f0f9ae42838452a9fafe52e03366ec8a31f4eca
160 hours, perfect!
Then a regular renewal was due, shortly before I posted about my problem 16h ago:
Issuer = C=US, O=Let's Encrypt, CN=E8
Not Before = 2025-12-23 16:11:41 +0000 UTC
Not After = 2026-03-23 16:11:40 +0000 UTC
Log Entry = 83327374 @ https://tuscolo2026h1.skylight.geomys.org/
crt.sh = https://crt.sh/?sha256=d3435210c446e3c63ff106c416a74b7a0a6bfa81b40dc6a518c7d1179e62b1ac
Back to 3 months – why? It should still be on the shortlived profile.
I'm using Traefik 3.6.5 in Docker version 26.1.5 on Debian 13. Sadly, Traefik doesn't really produce useful log output – hopefully you have some on your side? I do have full access to my server(s) and I do not use control panels (graphical, I assume).
That did not use tlsserver. You can see at crt.sh link or the cert itself that it has a Common Name. tlsserver certs will not have one. See Profiles - Let's Encrypt
This more strongly points to a traefik and/or its acme client problem
Something is different between your one-time request and renewal
I investigated more into this and found out Traefik is indeed using a different code path for new orders and renewals (so there is a difference).
And it seems the profile is indeed ignored for renewals. I filed a report there, let's see what they say:
