Docker Compose Traefik 2 not renewing certs
My domain is: cffsapps.net
I ran this command: docker restart traefik
It produced this output: certificate field says Null after trying to force a renew.
My web server is (include version): not the issue
The operating system my web server runs on is (include version): Ubuntu 20.04.4
My hosting provider, if applicable, is: Cloudflare
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): traefik:2.2.1
Well, that's a fairly complex set of pieces and you haven't given many details to work with.
Are you specifically concerned with problems just with your apex domain: cffsapps.net ?
Because that is behind Cloudflare's CDN. Which is acquiring certs with its Universal SSL for use in its edge locations. But I see HTTPS connections to your apex working fine so I am puzzled what the problem is there.
I see you recently got certs for various subdomains of that domain. Is it one or more of those that is a problem?
Are you using Traefix running inside Docker to get a cert for HTTPS between the CDN Edge and your Origin server?
I have so many questions about your post I am not sure where to begin. Any more details would be helpful. Errors from a log would be better than just "certificate field says null".
Hi @RobCFFS, and welcome to the LE community forum :slight_smile:
Please post some detail on any cert with that problem.
