Please see:
Not sure my reply to this went through, probably user error
In repy to my issue with deleting my SSL’s from Siteground server using the Cpanel bc/ of an unknown issue, and how to find the CRT and Private keys since you never actually see them using the automated Siteground installer.
Site ground has a .ssl hidden folder at the root that has a certificate folder and a private key folder. You can then use the SSL Manager and install it manually by copying and pasting into the Certificate Textarea and then the Private key into the Private Key textarea. Thanks man this got me pointed in the right direction and resolved my issue. Site is now secure.
If I followed correctly, the limiting factor is oscp signing every 4 days for every valid certs. As revoking a cert only needs one ocsp signing, period, it could actually raise the limit.
