I'm using nginx proxy manager for managing certificates, so can't say much at time.
Only, since today is an old certificate shown if I try to load the site.
The Browswer output:
|Ausgestellt am|Sonntag, 20. Juli 2025 um 13:57:06|
|Gültig bis|Samstag, 18. Oktober 2025 um 13:57:05|
But up to yesterday all was ok and nobody has done anything on certificates here.
The nginx proxy manager has the followin information: Expieres: 15th July 2026, 4:03 pm
what should the correct data.
If I try to generate the certificate new, there is no error coming up, but also don't see any change in browser and also no change in proxy manager.
Is there a problem in the let's Encrypt database since today on this entry?
All other domains are running without problems here, all with let's Encrypt certificates on the same server and reverse proxy.
There is no such thing. Certificates are signed and issued. They are not kept in some sort of database at Let's Encrypt to which browsers can connect, the server which was issued the certificate sends it to the browser in the connection handshake.
And your server somehow is sending an ancient certificate. Which is weird indeed. But well, that's NPM for you I guess (nobody around here likes that piece of software..)
Yes, after the first fail I restart the VM and wasn't coming up so right so I have reinstall a backup.
But the data of the backup should had the correct certificates on board and all outdated in the future. So I wondering, why are upcoming nearly one year outdated certificates from anywhere?
Oh, is this software so bad?
Is there anything new what I could using for that and what can I do for renew my certificates?
Thank you for clearing anything in understanding the technique!
Oh, yes, that's a good point if it is difficult to debug!
A reverse proxy here is the only method what makes sense for any servers at home. But I try to fix it or set it up for new. Hoping I'll find a way ...
Oh, have seen now, all my certificates are correct now again! ... wtf!?
I've done nothing since yesterday. All certificates are new now.
Ok, hopefully it works well in the future!
