Problem with SSL certificate on nginx proxy manager
My domain is: sappigeserver.ch
I ran this command: obtain SSL certificate on Nginx proxy manager
I have my proxy manager working and also the proxy entries. But I can't get a certificate for my domain. It says it is unreachable and I get the following error. The log file is non existent.
 Error: Command failed: certbot certonly --config
 "/etc/letsencrypt.ini" --cert-name "npm-2" --agree-tos --
authenticator webroot --email "email@gmail.com" --
preferred-challenges "dns,http" --domains "domain.ch"
  An unexpected error occurred:
 requests.exceptions.ConnectionError:
 HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org',
 port=443): Max retries exceeded with url: /directory (Caused by
 NewConnectionError(': Failed to establish a new connection:
 [Errno -3] Temporary failure in name resolution'))
 Ask for help or search for solutions at
 https://community.letsencrypt.org/. See the logfile
 /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v
 for more details.
   at ChildProcess.exithandler (node:child_process:397:12)
   at ChildProcess.emit (node:events:390:28)
   at maybeClose (node:internal/child_process:1064:16)
   at Socket. (node:internal/child_process:450:11)
   at Socket.emit (node:events:390:28)
   at Pipe. (node:net:687:12)
hostpoint?
linux mint 20.3
hostpoint.ch
im just using my host's conf. otherwise it redirects to my homeserver.
Dont know where to find that, I installed the nginx proxy manager through a docker-compose file.
You probably need to configure the resolver for the container.
