TLS-SNI-01 Renew - Could not bind to port 80
After reading this site: How to stop using TLS-SNI-01 with Certbot I followed the description and when trying point 3 - Renew Certificate - I get the described problem with port 80.
My Apache is configured for Listening to Port 80, but the message still appears.
Since my only knowledge was on how to setup letsencrypt the first time and how to renew the certificate using certbot, I am not quite sure on how to proceed know, as I cannot do anything and have no idea on how to switch to DNS-01 Challenge or use another ACME?!?
My domain is: afterguard.de
I ran these commands:
sudo sh -c “sed -i.bak -e ‘s/^(pref_challs.)tls-sni-01(.)/\1http-01\2/g’ /etc/letsencrypt/renewal/; rm -f /etc/letsencrypt/renewal/.bak”
sudo certbot renew --dryrun
Processing /etc/letsencrypt/renewal/jira.afterguard.de.conf
http-01 challenge for jira.afterguard.de
Attempting to renew cert (jira.afterguard.de) from /etc/letsencrypt/renewal/jira.afterguard.de.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6… Skipping.
Processing /etc/letsencrypt/renewal/afterguard.de.conf
http-01 challenge for afterguard.de
Waiting for verification…
Attempting to renew cert (afterguard.de) from /etc/letsencrypt/renewal/afterguard.de.conf produced an unexpected error: Failed authorization procedure. afterguard.de (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://afterguard.de/.well-known/acme-challenge/sTUl4qNT9dy2piHWLH1aOicF5Xy_Vad0gyYWICSci2E [2a02:2350:5:100:4180:0:cd18:d4eb]: 403. Skipping.
Processing /etc/letsencrypt/renewal/confluence.afterguard.de.conf
http-01 challenge for confluence.afterguard.de
Attempting to renew cert (confluence.afterguard.de) from /etc/letsencrypt/renewal/confluence.afterguard.de.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6… Skipping.
/etc/letsencrypt/live/jira.afterguard.de/fullchain.pem (failure)
/etc/letsencrypt/live/afterguard.de/fullchain.pem (failure)
/etc/letsencrypt/live/confluence.afterguard.de/fullchain.pem (failure)
3 renew failure(s), 0 parse failure(s)
My web server is (include version): apache2
My hosting provider, if applicable, is: Hetzner
certbot 0.28.0
standalone is for when you have no webserver running at all.
Assuming you have Apache running on 80 (and not Varnish), you should be able to just run:
certbot renew -a apache --dry-run
You are correct, when first initalising the certificates I did this standalone. As the whole process was much easier...
I later added the apache to the configuration, but stayed on the standalone.
When using you command, I receive the following:
Plugins selected: Authenticator apache, Installer None
Attempting to renew cert (jira.afterguard.de) from /etc/letsencrypt/renewal/jira.afterguard.de.conf produced an unexpected error: Failed authorization procedure. jira.afterguard.de (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://jira.afterguard.de/.well-known/acme-challenge/LGVvB6J1he3BdHHuJaVCoU5qfdXionXEDVBPgnjg0fY [2a02:2350:5:100:4180:0:cd18:d4eb]: 403. Skipping.
Attempting to renew cert (afterguard.de) from /etc/letsencrypt/renewal/afterguard.de.conf produced an unexpected error: Failed authorization procedure. afterguard.de (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://afterguard.de/.well-known/acme-challenge/CMdXHdeCIkfAauK8iigLCS17V07Hm2ljOf3fkA3lkVQ [2a02:2350:5:100:4180:0:cd18:d4eb]: 403. Skipping.
Attempting to renew cert (confluence.afterguard.de) from /etc/letsencrypt/renewal/confluence.afterguard.de.conf produced an unexpected error: Failed authorization procedure. confluence.afterguard.de (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://confluence.afterguard.de/.well-known/acme-challenge/wuELZ9s0wwl9QbIL2WuH0daAPEEEY8xSXj9neKadlFw [2a02:2350:5:100:4180:0:cd18:d4eb]: 403. Skipping.
Is there a way to get the standalone version to work via port80, as this was always pretty simple?
well technically you can just set Apache to not listen on port 80, but that will obviously disable site access by http.
Hi @DonMarco
you have ipv4- and ipv6 - addresses (checked with https://check-your-website.server-daten.de/?q=afterguard.de ):
afterguard.de A 46.30.213.6 yes 1 0
AAAA 2a02:2350:5:100:4180:0:cd18:d4eb yes
www.afterguard.de A 46.30.213.6 yes 1 0
But a list of curious answers:
46.30.213.6 503 0.090 S
Service Unavailable
2a02:2350:5:100:4180:0:cd18:d4eb 503 0.086 S
Service Unavailable
http://www.afterguard.de/
Service Unavailable
2a02:2350:5:100:4180:0:cd18:d4eb 503 0.073 S
Service Unavailable
https://afterguard.de/
46.30.213.6 503 1.710 S
Service Unavailable
2a02:2350:5:100:4180:0:cd18:d4eb 503 1.373 S
Service Unavailable
https://www.afterguard.de/
46.30.213.6 503 1.420 S
Service Unavailable
2a02:2350:5:100:4180:0:cd18:d4eb 503 1.406 S
Service Unavailable
http://afterguard.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
46.30.213.6 403 0.084 M
Forbidden
2a02:2350:5:100:4180:0:cd18:d4eb 403 0.073 M
Forbidden
http://www.afterguard.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
46.30.213.6 403 0.070 M
Forbidden
2a02:2350:5:100:4180:0:cd18:d4eb 403 0.084 M
Forbidden
So there are a lot of "Service Unavailable" messages, but /.well-known/acme-challenge/unknown-file answers with a 403 - Forbidden.
The headers are shorter. Why is there such an answer?
Are your DNS records correct?
Is http://afterguard.de/ supposed to return some sort of One.com ‘this web spage has expired and is suspended’ page?
Yes, the afterguard.de and the www.afterguard.de are currently unused, as they are completly work in progress. That’s why these links show in the void.
The only thing I am trying to get to back to working (for the moment) are jira.afterguard.de and confluence.afterguard.de
The webpage is being moved tomorrow away from one.com to hetzner. That shouldn’t raise a problem today, but I have to check…
The third domain has the same picture. Service Unavailable and Forbidden in /.well-known/...
So your server isn't really online.
Then we should wait and check it tomorrow again.
Solved… the webspaces move procedure has been started before schedule. Before I was able to change the certificates. Everything is working!
