TLS handshake error map acme: Could not determine solvers] Could not find solver for: dns-01 Could not find solver for: http-01
My domain is: chat.mountain-software.eu
I ran this command: sudo systemctl status mattermost -l
2018/01/22 10:00:44 [INFO][chat.mountain-software.eu] acme: Obtaining bundled SAN certificate
2018/01/22 10:00:44 [INFO][chat.mountain-software.eu] AuthURL: https://acme-v01.api.letsencrypt.org/acme/authz/xzPCIN1AAv4l6HleikzQynaIJQ4nyAF396konhmmDgI
2018/01/22 10:00:44 [INFO][chat.mountain-software.eu] acme: Could not find solver for: dns-01
2018/01/22 10:00:44 [INFO][chat.mountain-software.eu] acme: Could not find solver for: http-01
2018/01/22 10:00:45 http: TLS handshake error from 192.168.1.254:50850: map[chat.mountain-software.eu:[chat.mountain-software.eu] acme: Could not determine solvers]
2018/01/22 10:00:45 http: TLS handshake error from 80.154.65.20:44531: map[chat.mountain-softwaare.eu:[chat.mountain-software.eu] acme: Could not determine solvers]
Vodafone
Identifier status is deactivated, why, can someone explain me :
“identifier”: {
“type”: “dns”,
“value”: “chat.mountain-software.eu
“status”: “deactivated”,
“expires”: “2018-01-29T09:04:28Z”,
“challenges”: [
“type”: “dns-01”,
“status”: “pending”,
“uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/xzPCIN1AAv4l6HleikzQynaIJQ4nyAF396konhmmDgI/3187876570”,
“token”: “EakVigq5L-c2VzUd4bHphmB24PFW6ddhtShNSnuosGE”
“type”: “http-01”,
“uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/xzPCIN1AAv4l6HleikzQynaIJQ4nyAF396konhmmDgI/3187876571”,
“token”: “sDhIw65GnOXNjcf_Jj1ZdF93lA8RGCQL8K0gWj2_GAo”
“combinations”: [
0
1
Hi @electronix001,
This is probably a result of this issue:
If Mattermost has its own internal support for obtaining certificates, it may be hardcoded to use the TLS-SNI-01 method, which is no longer available. If that's so, you should let the Mattermost developers know about this problem because they'll need to switch over to one of the other methods now.
Based on the log output, I’m guessing that Mattermost is written in Go (because the log output matches Go’s style). From that I’m further guessing that it may use the Go autocert package. If so, that package recently incorporated some changes to switch to the HTTP-01 challenge. So, try updating your Mattermost install. If that doesn’t work, notify the Mattermost developers that they need to update their Let’s Encrypt integration, and if that happens to be autocert, there’s an update ready to be incorporated into their project.
Thank’s for your answer, already wrote them about.
This is the thread, for anyone also having the issue (like me!). Please include it the next time :slight_smile:
Thanks for sharing that thread. Here’s another one I found from links there, that promises a hotfix release this week: https://forum.mattermost.org/t/workaround-for-broken-lets-encrypt-certificates-on-mattermost-servers/4459
