I did not run any, I am using nginx-proxy with letsencrypt-nginx-proxy-companion docker images for various sub domain, each container is set for one subdomain.
(just one example, but I got more subdomains with the same issue, also it always worked fine until recently)
Creating/renewal server-queue.roxypony.fr certificates... (server-queue.roxypony.fr)
2017-06-30 13:48:10,972:INFO:requests.packages.urllib3.connectionpool:756: Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
2017-06-30 13:48:12,331:INFO:requests.packages.urllib3.connectionpool:242: Resetting dropped connection: acme-v01.api.letsencrypt.org
2017-06-30 13:48:13,099:INFO:requests.packages.urllib3.connectionpool:207: Starting new HTTP connection (1): server-queue.roxypony.fr
2017-06-30 13:48:13,103:INFO:requests.packages.urllib3.connectionpool:756: Starting new HTTPS connection (1): server-queue.roxypony.fr
2017-06-30 13:48:13,133:INFO:simp_le:1305: server-queue.roxypony.fr was successfully self-verified
2017-06-30 13:48:13,451:INFO:simp_le:1313: Generating new certificate private key
2017-06-30 13:48:22,973:ERROR:simp_le:1271: CA marked some of the authorizations as invalid, which likely means it could not access http://example.com/.well-known/acme-challenge/X. Did you set correct path in -d example.com:path or --default_root? Is there a warning log entry about unsuccessful self-verification? Are all your domains accessible from the internet? Failing authorizations: https://acme-v01.api.letsencrypt.org/acme/authz/-WibFGul4k9LAcp6QgQiILL9QNn2nQ-Aml12DwQ-tlk
Challenge validation has failed, see error log.
When I try to fetch the challenge myself I never get those tiemouts, Idon’t know what’s wrong but maybe you can help me see throught it.
Thx
