My domain is: atlas-disc.loca.lt
I ran this command: certbot certonly --webroot
←[31mChallenge failed for domain atlas-disc.loca.it←[0m
http-01 challenge for atlas-disc.loca.it
←[31mSome challenges have failed.←[0m
←[1m
←[0m - The following errors were reported by the server:
Domain: atlas-disc.loca.it
Type: connection
Detail: Fetching
http://atlas-disc.loca.it/.well-known/acme-challenge/NcBVhQwYrnsZD1F0qce56XGxHQTT9dV2KN544MYKMzg:
My web server is (include version):*
The operating system my web server runs on is (include version):*
My hosting provider, if applicable, is:*
I can login to a root shell on my machine (yes or no, or I don't know):*
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):*
*: I'm on Windows 10, I'm using MAMP to host and LocalTunnel to portforward. I check with https://check-your-website.server-daten.de/?q=atlas-disc.loca.lt and I didn't find any problem.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.13.0
