DDPrak
April 13, 2023, 10:35am
1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: cello-master.nedalert.nl
I ran this command: certbot certonly --webroot --test-cert --http-01-port 88 -v -d cello-master.nedalert.nl
Domain: cello-master.nedalert.nl
Type: connection
Detail: 185.168.200.31: Fetching http://cello-master.nedalert.nl/.well-known/acme-challenge/HRvclMNIHmjORqoIBEXmGBr8BIW0wrE0Tqs_TE7fDIA: Timeout during connect (likely firewall problem)
apache2.4.51
Windows Server 2022 Standard 21H2
vdp-automation (Own Platform)
Yes
no
or certbot-auto --version
if you're using Certbot):
certbot 2.2.0
_az
April 13, 2023, 10:37am
2
You can't change the port that the HTTP challenge happens over. It must be port 80, according to the rules that Let's Encrypt needs to follow.
FWIW I can't connect to your server on port 80 nor 88.
DDPrak
April 13, 2023, 10:46am
4
I would like to know , does that mean the webserver has to serv on port 80 , also after the challenge?
Sorry if i misunderstand the system demands.
DDPrak
April 13, 2023, 11:37am
5
With port 80 activated the response from Certbot is the same.
The Website is responding on port 80.
Any suggestions?
Port 80 still looks closed to me for cello-master.nedalert.nl
Osiris
April 13, 2023, 12:44pm
7
Port 80 is open for me in The Netherlands. Perhaps a geoblocking rule is active?
Yes, very much looks like a geographic based firewall.
DDPrak
April 13, 2023, 3:33pm
9
Thanks Osiris, MikMcQ,
The country blocking did the thing.
The certificate has been made.
Last job is to let my Apache work with it
first make sure your site is able to connect over phone without connecting your home wifi
Osiris
April 13, 2023, 6:44pm
11
With geoblocking and assuming the phone service is in the same country as the server, that wouldn't really matter But in general you're right indeed
system
Closed
May 13, 2023, 6:45pm
12
