Ok now you have your shoes on and the are ready for walking.
Maybe even RUNning!
is it working on your network?
https://sturtz.ml
you should see
I can only see in text LOL:
<!DOCTYPE html>
<html class="ng-csp" data-placeholder-focus="false" lang="en" data-locale="en" >
<head
data-requesttoken="vSzrbXWmtvGwNtpXe3xwvNZZuUVAyhLsJqkUAVjZgrM=:+XWkD17L8sfJVO0mLyYF36Ez0SQmqUeuFuxnbCGb2ss=">
<meta charset="utf-8">
<title>
Nextcloud </title>
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0, minimum-scale=1.0">
<meta name="apple-itunes-app" content="app-id=1125420102">
<meta name="theme-color" content="#0082c9">
<link rel="icon" href="/core/img/favicon.ico">
<link rel="apple-touch-icon" href="/core/img/favicon-touch.png">
<link rel="mask-icon" sizes="any" href="/core/img/favicon-mask.svg" color="#0082c9">
<link rel="manifest" href="/index.php/apps/theming/manifest?v=0">
<link rel="stylesheet" href="/apps/files_pdfviewer/css/style.css?v=4fda350b-0">
<link rel="stylesheet" href="/core/css/guest.css?v=c439af14-0">
<script nonce="dlN6cmJYV210dkd3TnRwWGUzeHd2TlpadVVWQXloTHNKcWtVQVZqWmdyTT06K1hXa0QxN0w4c2ZKVk8wbUx5WUYzNkV6MFNRbXFVZXVGdXhuYkNHYjJzcz0=" de
fer src="/index.php/core/js/oc.js?v=c439af14"></script>
<script nonce="dlN6cmJYV210dkd3TnRwWGUzeHd2TlpadVVWQXloTHNKcWtVQVZqWmdyTT06K1hXa0QxN0w4c2ZKVk8wbUx5WUYzNkV6MFNRbXFVZXVGdXhuYkNHYjJzcz0=" defer src="/core/j
s/dist/main.js?v=c439af14-0"></script>
<script nonce="dlN6cmJYV210dkd3TnRwWGUzeHd2TlpadVVWQXloTHNKcWtVQVZqWmdyTT06K1hXa0QxN0w4c2ZKVk8wbUx5WUYzNkV6MFNRbXFVZXVGdXhuYkNHYjJzcz0=" defer src="/index.
php/js/core/merged-template-prepend.js?v=c439af14-0"></script>
<script nonce="dlN6cmJYV210dkd3TnRwWGUzeHd2TlpadVVWQXloTHNKcWtVQVZqWmdyTT06K1hXa0QxN0w4c2ZKVk8wbUx5WUYzNkV6MFNRbXFVZXVGdXhuYkNHYjJzcz0=" defer src="/core/s
earch/js/search.js?v=c439af14-0"></script>
s/backgroundjobs.js?v=c439af14-0"></script>
<script nonce="dlN6cmJYV210dkd3TnRwWGUzeHd2TlpadVVWQXloTHNKcWtVQVZqWmdyTT06K1hXa0QxN0w4c2ZKVk8wbUx5WUYzNkV6MFNRbXFVZXVGdXhuYkNHYjJzcz0=" defer src="/apps/f
iles_sharing/js/dist/main.js?v=c439af14-0"></script>
iles_pdfviewer/js/previewplugin.js?v=c439af14-0"></script>
iles_videoplayer/js/main.js?v=c439af14-0"></script>
earch/js/searchprovider.js?v=c439af14-0"></script>
s/files/fileinfo.js?v=c439af14-0"></script>
s/files/client.js?v=c439af14-0"></script>
s/dist/login.js?v=c439af14-0"></script>
<link rel="stylesheet" href="/index.php/apps/theming/styles?v=0"/><script defer src="/index.php/apps/theming/js/theming?v=0" nonce="dlN6cmJ
YV210dkd3TnRwWGUzeHd2TlpadVVWQXloTHNKcWtVQVZqWmdyTT06K1hXa0QxN0w4c2ZKVk8wbUx5WUYzNkV6MFNRbXFVZXVGdXhuYkNHYjJzcz0="></script><script defer src="/index.php/a
pps/accessibility/js/accessibility?v=0" nonce="dlN6cmJYV210dkd3TnRwWGUzeHd2TlpadVVWQXloTHNKcWtVQVZqWmdyTT06K1hXa0QxN0w4c2ZKVk8wbUx5WUYzNkV6MFNRbXFVZXVGdXhu
YkNHYjJzcz0="></script><meta property="og:title" content="Nextcloud"/><meta property="og:description" content="a safe home for all your data"/><meta proper
ty="og:site_name" content="Nextcloud"/><meta property="og:url" content="https://sturtz.ml/"/><meta property="og:type" content="website"/><meta property="og
:image" content="https://sturtz.ml/core/img/favicon-touch.png"/> </head>
<body id="body-login">
<noscript>
<div id="nojavascript">
<div>
This application requires JavaScript for correct operation. Please <a href="https://www.enable-javascript.com/" target="_blank" rel
="noreferrer noopener">enable JavaScript</a> and reload the page. </div>
</div>
</noscript>
<input type="hidden" id="initial-state-core-loginUsername" value="IiI=">
<input type="hidden" id="initial-state-core-loginAutocomplete" value="dHJ1ZQ==">
<input type="hidden" id="initial-state-core-loginThrottleDelay" value="MA==">
<input type="hidden" id="initial-state-core-loginResetPasswordLink" value="IiI=">
<input type="hidden" id="initial-state-core-loginCanResetPassword" value="dHJ1ZQ==">
<input type="hidden" id="initial-state-core-webauthn-available" value="dHJ1ZQ==">
<div class="wrapper">
<div class="v-align">
<header role="banner">
<div id="header">
<div class="logo">
<h1 class="hidden-visually">
Nextcloud </h1>
</div>
</div>
</header>
<main>
<div id="login"></div>
</main>
</div>
</div>
<footer role="contentinfo">
<p class="info">
<a href="https://nextcloud.com" target="_blank" rel="noreferrer noopener" class="entity-name">Nextcloud</a> – a safe home f
or all your data </p>
</footer>
</body>
</html>
Thank you!!!
Yes, now it works.
@rg305 : No raw ipv6 support? Terrible
@JuergenAuer, yes and such a simple fix too.
It’s 2020 - IPv6 support should be included by default !
Yep.
Last year I've changed (ISDN + DSL to DSL + IP). Now ipv4 + ipv6 is included.
Thanks for all your help!
I started, getting the error again
Which error exactly?
I see the introduction of CloudFlare:
curl -6Iki http://sturtz.ml/
Date: Fri, 28 Aug 2020 05:23:59 GMT
Cache-Control: max-age=3600
Expires: Fri, 28 Aug 2020 06:23:59 GMT
cf-request-id: 04d51ede5d0000ef0a40b32200000001
X-Content-Type-Options: nosniff
Server: cloudflare
CF-RAY: 5c9b9a76faddef0a-MIA
alt-svc: h3-27=":443"; ma=86400, h3-28=":443"; ma=86400, h3-29=":443"; ma=86400
Addresses: 2606:4700:3036::681b:a0fb
2606:4700:3032::ac43:9e40
2606:4700:3034::681b:a1fb
104.27.160.251
104.27.161.251
172.67.158.64
I got it fixed, Also can you access my website? I think I am having issues again?
I am unable to connect
What now is going on.
I get no response from [2604:99c0:8:2f0f:223:24ff:fe08:581f]
Has your IP changed?
I don’t think so
nsturtz@sturtz001:~$ ip address
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:23:24:08:58:1f brd ff:ff:ff:ff:ff:ff
inet 192.168.1.8/24 brd 192.168.1.255 scope global dynamic enp0s25
valid_lft 85781sec preferred_lft 85781sec
inet6 fe80::223:24ff:fe08:581f/64 scope link
LOL
The IPv6 address is gone.
What, How? I contacted my ISP about Static ips, then this happened now they are leaving me on read in there live chat
Who manages your router ?
