My domain is: xazzi.co.uk
My web server is (include version): IIS 10
The operating system my web server runs on is (include version): Server 2019
My hosting provider, if applicable, is: self hosting
I can login to a root shell on my machine (yes or no, or I don't know): N/A
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): N/A
or certbot-auto --version
if you're using Certbot): win-acme.v2.1.14.996.x64
This file accessible over port 80 & 443 http://hyperion.xazzi.co.uk/.well-known/acme-challenge/test.txt
I get the error below
` Target generated using plugin IIS: hyperion.xazzi.co.uk
[hyperion.xazzi.co.uk] Authorizing...
[hyperion.xazzi.co.uk] Authorizing using http-01 validation (SelfHosting)
[hyperion.xazzi.co.uk] Authorization result: invalid
[hyperion.xazzi.co.uk] {
"type": "urn:ietf:params:acme:error:connection",
"detail": "During secondary validation: Fetching http://hyperion.xazzi.co.uk/.well-known/acme-challenge/GNeoc5LE6DPTvj-_oNF5Evv-cke6ZHI27ngYuCoNLLQ: Timeout during connect (likely firewall problem)",
"status": 400
I have looked at the other threads with the same title but can't find anyone useing IIS
