I have a same problem.
An unexpected error occurred:
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='acme-staging-v02.api.letsencrypt.org', port=443): Read timed out. (read timeout=45)
@vasilialex There are many reasons why that can happen. I moved your post into its own thread so we can better focus on your specific problem.
Had you posted in Help section, you would have been shown the form below. Please answer as much as you can.
Be sure to explain what you were doing when you got the error. Were you running something from a command prompt? Or from a container. Or a system like NPM. Are you able to connect outbound to other domains?
or certbot-auto --version
if you're using Certbot):
